e30 Keyless Entry (Sold Out)
  • Isostar13
    • Nov 2011
    • 288
    #136
    Ah... thanks. All the chimes work for me (key/door/36'F), I just never knew where it came from.
    Well, for anyone else with this piece still in place, be careful when attaching your remote receiver on the ABS computer. This piece will get in the way.
    1988 325ix
    • wh00sh
      • Dec 2010
      • 68
      #137
      Thanks for the pics of the '88 ix wiring. I just ordered one of these, and will confirm whether or not this was unique to your car. My guess is this wiring will be found on any E30 with the premium audio, which was standard on the '88 ix.
      '88 iX Money Pit/Labor of Love
      • FLG
        • Sep 2011
        • 3165
        #138
        Glad it worked out for you! I guess wiring might differ a bit...mine is a 87 IS if anyone is wondering.
        Also i attatched it to the abs computer but all the way to the left near the kick panel area, away from the door chime.
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • einstein57
          • Jun 2007
          • 10780
          #139
          Sorry for the delay on a installation video or picture writeup. I've had several locals swear they would post detailed writeups but have not come through yet. I did not want to use my e28 and my e30 has everything tucked away as I installed mine with the dash removed.
          Originally posted by sergio318is
          does this sound the alarm if door open while car is in lock like with stock BMW alarm remote ??
          Sent from my iPhone 4s using Tapatalk
          There is no alarm feature for the unit.
          www.gecoils.com
          • Isostar13
            • Nov 2011
            • 288
            #140
            Just beware as you get in there, the Y/B and G/B wires are in a really tight spot down there. I was planning on using heat shrink butt connectors as FLG suggested, but once I found the right wires, there just was no room to fit the connectors. I could barely get a tool in there to splice it... an extremely tight fit.
            Anyone have better luck re-attaching the huge clip on the steering column? For me there is too much resistance trying to push it up to get the clip back in the metal slots. How did you do it?
            1988 325ix
            • FLG
              • Sep 2011
              • 3165
              #141
              A lot of patience. Also might help if you remove one of the blocks off of it...hard to explain but the block of connectors separates further into smaller blocks if I remember it was easier to remove the next largest block , clip the first one back on the column than put that one back on.
              Sent from my Galaxy Nexus using Tapatalk
              • MaxBell
                • 1391
                #142
                The instructions that come with it are more specific on where I'm looking, what to take apart, etc?
                REMEMBER: Be safe and have fun is Rule Number 1.
                The Epic Unbuild of Clint Eastwood
                • Isostar13
                  • Nov 2011
                  • 288
                  #143
                  Originally posted by MaxBell
                  Are the instructions that come with it more specific on where I'm supposed to look, what to take apart, etc?
                  No, not really, but to be honest, FLG's guide on page 6 is more than adequate to do it right. The only tricky part for me was actually finding the lock/unlock wires. As shown in my pictures on page 9, my wires were buried deep down, almost below my left front speaker.
                  If you take off the panel under your steering wheel, and then remove the driver's side kick panel (exposing your speaker), you'll see the bundle of 4 held on by the black plastic clip (as described by FLG.) If your wires are not in that bundle of 4, look right below them, and you'll probably see another bundle running perpendicular to those 4. That's where mine were.
                  1988 325ix
                  • Isostar13
                    • Nov 2011
                    • 288
                    #144
                    A quick note on tools: FLG mentioned that he used butt connectors and heat shrink tape. Before doing this, I would recommend looking up the wire gauges in a bentley manual, and buying splicers for those gauges.
                    All in all I picked up the following from Home Depot before starting:
                    Wire cutter/stripper/crimper tool.
                    Butt connectors in 3 sizes (I didn't measure gauges).
                    Electrical tape.
                    Grounding ends.
                    Small zip ties.
                    Butane torch (for the heat shrink connectors.)
                    If I were going to do it all again I would pick up a few "quick splices" at Home Depot as well. In fact, I may go back in on mine and re-do some of my splices.
                    I hope this helps.
                    1988 325ix
                    • bernzpeed
                      • 3917
                      #145
                      can't you use T taps instead? would that make it easier?
                      89 E30 S52
                      Transaction Feedback.
                      • ZM Blue Devil
                        • Dec 2006
                        • 13836
                        #146
                        bingo;)
                        Levent
                        %20levent@gutenparts.com
                        Ladies:
                        • Isostar13
                          • Nov 2011
                          • 288
                          #147
                          After reading your comment, I googled "t-taps how to". Wow, I wish I had heard of these before yesterday.
                          Yes, that would have made things a LOT easier getting into the lock/unlock wires.
                          1988 325ix
                          • einstein57
                            • Jun 2007
                            • 10780
                            #148
                            That's whay I use. I'll be picking up a huge bag of them this weekend to include with the kits.
                            www.gecoils.com
                            • FLG
                              • Sep 2011
                              • 3165
                              #149
                              T-taps are nice would make things easier...it was tight but I had enough of wire slack to use, just had the butt connectors and heat shrink handy.
                              • george graves
                                • 19992
                                #150
                                I highly recommend that you try to buy the 3M brand of t-taps.
                                Originally posted by Matt-B
