“Bavauto” Headers Group Buy
  • Gary Horneck
    • May 2011
    • 435
    #31
    Crap, I Rallycross my car and need every millimeter of clearance I can find. I have the i exhaust system solidly bolted way up in there, and I still hit the flanges on the the mid-pipe/muffler sometimes. How much of a beating would they stand up to?
    2011 335i/1995 Mercedes C220 (rallyx)
    • ehnaych
      • Nov 2008
      • 28
      #32
      1) Bullet Ride 325, mid-section included, coated, 1 set.
      2) Gary Horneck 325, mid section included, uncoated, 1 set (R3V)
      3) tinkerputzer, 325, midsection included, coated, 1 set (R3V)
      4) delatlanta1281, 325, mid-section included, coated, 1 set (R3V)
      5) Van Westervelt, 325, mid-section included, uncoated, 1 set (R3V)
      6) Slippery, 325, mid-section included, uncoated, 1 set (R3V)
      7) Mendi3, 325, mid-section included, uncoated, 1 set (R3V)
      8.) Irish1, 325, no mid-section, coated, 1 set (BFC)
      9) n0m4d 325, mid-section included, uncoated, 1 set (R3V)
      10)ehnaych, 325, mid-section included, uncoated, 1 set (R3V)
      • DTMbimmer07
        • 1485
        #33
        I slam them like every day on dips and speed bumps etc. there still good but just rather flat and the metal is wearing thin
        • Mfever
          • May 2007
          • 1058
          #34
          Would the coating be the same as the bavarian autosport ceramic? I know the jet coating was really durable and looked great. Just wondering if their coaters will have the same look/durability.
          • Bullet Ride
            • Dec 2010
            • 598
            #35
            I'll ask the guy building the headers to give some feedback on the coating. Other than that I can't say anything about the coating. If you're skeptical, you can always buy an uncoated set and take them to a coater that you know does quality work.
            • Bullet Ride
              • Dec 2010
              • 598
              #36
              I talked to Tubular at lunch today and got some questions answered. They are currently looking into pricing and availability of the material and should have that on Monday.
              Originally posted by LJ851
              Are you sure the headers are 1 3/8" ?
              I confirmed that the headers have 1 3/8" OD primaries.
              Originally posted by n0m4d
              Uncoated please. Next time you speak with them can you ask if they would be ok with someone picking up a set instead of shipping? I am close enough that I could find a reason to shoot down to Mass.
              Thanks for organizing this.
              They said sure no problem.
              They said the place that's doing the coating has been doing coatings for 20 years. The coating that is used on the cone of the space shuttle was developed by the guy who's running the shop. With specific regard to the headers, the process is as follows:
              1. Chemical dipped to clean them
              2. Blasted to remove any scale or other debris that the dip did not remove
              3. Coated inside and out
              4. Baked
              5. Blasted with softer media (i.e. walnut shell)
              6. Second coating on outside
              7. Baked
              8. Polished in a bead tumbler
              I was told the second coating is done just so that when they are polished it's not removing material from what would be the protective layer.
              • slippery
                • Nov 2011
                • 373
                #37
                Bullet,
                can you change mine to coated? Thanks,
                J
                • Bullet Ride
                  • Dec 2010
                  • 598
                  #38
                  Originally posted by slippery
                  Bullet,
                  J
                  6) Slippery, 325, mid-section included, coated, 1 set (R3V)
                  10) ehnaych, 325, mid-section included, uncoated, 1 set (R3V)
                  11) supernaught, 325, no mid-section , coated, 1 set (max)
                  • Mfever
                    • May 2007
                    • 1058
                    #39
                    so durablilty is for sure... as far as aesthetics, will they look the same? just wanted to clarify.
                    • Bullet Ride
                      • Dec 2010
                      • 598
                      #40
                      Yeah, they should look similar.
                      • FLG
                        • Sep 2011
                        • 3165
                        #41
                        Also coating em will keep engine bay temps down.
                        Sent from my Galaxy Nexus using Tapatalk 2
                        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                        • Mfever
                          • May 2007
                          • 1058
                          #42
                          12) Mfever, 325, mid-section included , coated , 1 set (R3V)
                          • slippery
                            • Nov 2011
                            • 373
                            #43
                            What are the chance we can request an extra bung to be placed at the collector?
                            J
                            • Bullet Ride
                              • Dec 2010
                              • 598
                              #44
                              J
                              I'll ask when I call on tuesday.
                              11) supernaught, 325, mid-section included, coated, 1 set (max)
                              • delatlanta1281
                                Dart Master
                                • Mar 2006
                                • 10317
                                #45
                                J
                                Good call.
                                Yours truly,
                                Rich
                                you kids get off my lawn.....
