DTM92 Type Front Suspension for E30 / E36
  • maxx-automotive
    • Apr 2006
    • 87
    We are doing a batch of these front control arm / tie rod assemblies. Custom solutions for various struts possible. All joints with rod-ends or spherical bearings. This setup is mainly intended for track/race cars although can also be used for weekend "fast road" cars as well. If there is interest please send email or PM to info@s14power.com or sales@maxx-automotive.com
    This is late DTM92 style. It is the ultimate in light weight suspension, full geometry adjustability, steering precision and stiffness. This suspension will work on e30 and e36 chassis race cars and even some E46 cars have used DTM struts and suspension.
    version with raised inner control arm pickup point (modified subframe for the optimal control arm geometry for lowered cars. you dont have to run such large spacers at the outer control arm pickup and it will fit your rims easier):
    spare parts:
    control arm parts:
    Please note that the control arms are SIDE specific -- in contrast to some earlier setups which try to be universal.
    Assembly of Group A/DTM Front Axle E30/36
    The control arm must be attached to the clevis on the front subframe using spacers as shown in the picture above. The spacers ensure that the control arm's inner rod-end is correctly centered in the clevis.
    Torque: 100 Nm
    The control arm's outer joint is mounted using conus bearing as shown above. The mounting position can be adjusted using the supplied spacer. Installation of the spacer is not absolutely required.
    Torque on bottom nut: 90 Nm
    Installation of the fork on the radius arm and attachment to the control arm is shown in the above.
    Torque: 100 Nm
    Installation of the radius arm rod-end in the chassis mount is shown above. The supplied spacers must be used both above and below the rod-end to ensure proper clearance under all conditions.
    Torque: 100 Nm
    With the large spacers it is possible to adust the height of the radius arm and thus change the vehicles anti-dive characteristic. Moving the arm up results in less dive and moving the arm down in more dive when the car is braking.
    In order to secure the chassis mount which accepts the radius arm a hole must be drilled and the supplied threaded nut welded into the chassis rail.
    Diameter: 12.5 mm.Torque 42 Nm
    Use the supplied screws M12x1.5 to attach the other points of the radius arm mount to the chassis.
    Torque M12 screws: 105 Nm
    In order to achieve the stock wheel position, the control arm is adjusted to a length of 340 mm measured center to center between the bearing ends.
    Zoomed picture from above showing the control arm measurement.
    In order to achieve the stock wheel position, the radius arm is adjusted to a length of 435 mm measured between the center of the fork bolt hole and the rod-end center.
    Zoomed picture from above showing the radius arm measurement.
    Note that this is just a basic setting to give you a start. From here, you may want to increase the trackwidth and camber by adjusting the control arm outward. The camber change is in addition to whatever change your adjustable camber plates will allow. This change in trackwidth will not change your scrub radius (distance between the projection of your strut and wheel center). If you added a thicker wheel spacer e.g., you would increase your scrub radius.
  • Dj Buttchug
    • Jun 2010
    • 7680
    awesome!
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • M-technik-3
      • 18946
      Eric has this set up on his Henna M3. John sells first rate products so don't hesitate to purchase from him.
      • Hawkmec
        • May 2013
        • 53
        Price?
        • blck325is
          • Apr 2006
          • 1749
          Also in for price, thats awesome.
          Originally posted by csermonet47
          Vlad, you are handling this quite unprofessionally.
          Also, you are a cock with tacky taste.
          That is all.
          • mrcheezle19
            • Apr 2012
            • 1451
            price?
            Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
            • mr2peak
              • 2388
              It's free, he's looking for beta testers
              Drive it hard. Maintain it well.
              A Topless Memorandum
              • fight4life28
                • Apr 2014
                • 821
                Looks great, I would try them out if you needed someone to test them out.
                • maxx-automotive
                  • Apr 2006
                  • 87
                  hi, sorry for my late reply.
                  the base control arm kit is normally 2939 euro. In this batch they are 2351 euro. The rod-ends, spherical bearings, spacers, bolts etc. are included. Works with the stock steering knuckles and tie-rods. In addition, alternate application specific knuckles with modified angles for lowered cars are available for e30 and e36 along with tie rods and steering rack conversion to rod-end pickups. For proper placement of outer pickup points also need to know the size of the wheel (e.g. 17 or 18"). This setup is primarily intended for race/track cars or "fast road" DE cars etc. If anyone is interested its best if we discuss directly your specific desired setup or current setup.
