CF Airbox and Alpha N GB (S14/S50/S54/S65)
  • maxx-automotive
    • Apr 2006
    • 87
    2015 group buy for carbon intake systems (aka CF airbox), currently in progress, production ending Feb. 28, 2015.
    Hello, we are running a group buy on carbon airbox for s14, s50, s54, s65 powered e30 / e30 m3 / 2002 as well as other chassis (e28, e36, e46, etc). We also have alpha N system for certain engines (s14, s50, m20, m50, s38, etc). For S54 we can program the factory ECU in alpha N mode, delete EWS and integrate for other chassis like e30 or e36. We are located in Germany and specialize in these kind of setups. Our setups have been installed on a number of top running BMW CCA club race cars and also in cars featured in the roundel. Please have a look below for pictures of various installations.
    Airboxes are being manufactured now and shipping as they complete. So if your order is in early, you will receive your airbox earlier. Typical lead time from order to dispatch is approx. 2-3 weeks. The closing date for this group buy is Feb 28, 2015.
    If you are interested in participating and wish to have your name on the list, please send an email with your details (name, shipping address, part, etc.) to: info@s14power.com
    There are various carbon fiber airbox systems and air plenum intakes available. The airbox systems include snorkels and install kits where required. Some of the versions available:
    • E30 M3 S14 DTM CF airbox for 46, 48, 49 or 50 mm throttle bodies
    • E30 M3 S14 DTM CF airbox for S38 50 mm throttle body conversion
    • E30 M3 S14 DTM 8-injector CF airbox ('92 type with bottom mount injectors)
    • E30 M3 S14 CF replica plenum (weighs just 1.5 lbs)
    • 2002 M2 S14 CF airbox
    • E92 M3 S65 (for stock engine management)
    • E60 M5 S85 (for stock engine management)
    • E46 M3 S54 CF airbox (for Alpha N type engine management, 120 mm or 200 mm snorkel inlet)
    • E46 M3 S54 CF airbox (race version with central kidney intake)
    • E46 M3 S54 MAF CF airbox (for stock engine management, 120 mm snorkel inlet)
    • E36 M3 S50 CF airbox (for Alpha N type engine management)
    • E36 M3 S50 MAF CF airbox (for stock engine management)
    • E34 M5 S38 CF airbox (for Alpha N type engine management)
    Current group buy price list in euro (ca. 18-20% off). Prices are for complete kits so everything is included:
    CF Replica Plenum S14 : 640
    CF Airbox S14 46/18 with CF snorkel and install kit : 1165
    CF Airbox S14 48/18 with CF snorkel and install kit : 1165
    CF Airbox S14 49/18 with CF snorkel and install kit : 1195
    CF Airbox S14 50/18 with CF snorkel and install kit : 1195
    CF Airbox S14 50/18 (S38 TB) with CF snorkel and install kit: 1285
    CF Airbox S14 8-injector version with CF snorkel and install kit:
    CF Airbox S14 2002tii 46-50/18 with install kit : 1055
    CF Air Filter Housing for S14 (optional) : 150
    CF Airbox installation kit only : 150
    CF Airbox S50 : 1285
    CF Airbox S50 MAF : 1350
    CF Airbox S54 / 200 mm CF snorkel (internal filter) : 1595
    CF Airbox S54 / 120 mm CF snorkel (internal filter) : 1595
    CSL airfilter : 135
    CF Airbox S54 / 120 mm CF snorkel (external filter) : 1595
    CF Airbox S54 MAF / 120 mm CF snorkel : 1680
    CF Airbox S54 race with CF central intake snorkel : 1950
    CF Airbox S54 version II race with CF central intake snorkel :
    CF Airbox S65 (E92) : 1595
    CF Airbox S85 (E60) : 2150
    Maxx Alpha N V2.0 with WBO2 closed loop: 705
    TE WBO2 kit with WBO sensor LX1 remote display: 370
    Chip for S14 motronic: inquire (engine configuration dependent)
    Note: Schrick cams and other Schrick valve train parts available.
    Inquire for package deals which include Schrick parts and Maxx Alpha N.
    ECU software is available for S14, S50, S54, S65 and S85 using factory ECU. Options for engine installations into different chassis: EWS delete, speed signal delete, DSC delete, Cat monitoring delete, Alpha N mode, VMAX disable, etc. Drive-by-wire (electronically controlled TBs) can be retained when installing engines in different chassis.
    For S14 (E30 M3 and 2002tii) specific applications:
    Maxx Alpha N V2.0 with Wideband O2 closed loop control & lambda target map: 705 euro
    S14 DTM CF Airbox System -- large volume plenum, long runners, 46 or 48 mm diameter (49 & 50 mm also available, see above):
    • CF airbox with install kit: 950 euro
    • CF snorkel kit: 155 euro
    • Brake reservoir relocation kit: 60 euro (not required on race cars with dual master cylinders)
    Total CF Airbox kit: 1165 euro (Total minus install kit: 1050 euro)
    optional:
    CF air filter housing for inside front bumper (for use on non-AC cars or with custom AC radiator): 150 euro
    2002 S14 airbox (requires 2002tii brake booster):
    • CF airbox with install kit: 1035 euro
    • extra large air-hose: 20 euro
    NOTE: brake reservoir relocation kit and snorkel are not required on the 2002 setup.
    CF replica plenum for stock (AFM) installations: 640 euro
    Pictures of CF Airboxes / installations:
    S14 airbox:
    2002/S14 airbox installation:
    S14 CF replica plenum (for use with AFM / MAF / or Alpha N):
    E46/S54 airbox for use with MAF/HFM or Alpha N (also versions using alternate snorkels and internal or external air filters):
    E46/S54 airbox with central air intake from the "kidneys":
    E30/S54 airbox installation (for use with MAF/HFM or Alpha N):
    E92/S65 CF plenum installation:
    E36/S50 airbox for use with MAF/HFM or Alpha N:
    E34/S38 airbox installation:
    Alpha N kit:
    Maxx Alpha N Wideband O2 closed loop control:
    Pictures can also be found here: http://s14power.com/airboxes.html
    sales@maxx-automotive.com
  • Mfever
    • May 2007
    • 1058
    Any m20 cf boxes?
    • gath
      • 577
      Very impressive work. GLWS. But seriously? Every other BMW model but not even an attempt on M20? :hitler:
      May the M50 one can be modified to come up with one for M20.
      My $0.02
      • maxx-automotive
        • Apr 2006
        • 87
        We have worked on M20 before. But you should convert to individual throttles. Alpha N conversion for M20 is available. There were far more requests for S50 and S54 E30 versions, which is why we have those.
        • Pocket Chant
          • Mar 2012
          • 403
          Will these be available after the group buy (Obviously at higher prices)?
          I'm super interested but I'm halfway through rebuilding my suspension.
          1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
          MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
          Originally posted by MclubSport
          Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
          Horrible with responding to PMs, I'm so sorry.
          • maxx-automotive
            • Apr 2006
            • 87
            yes, they will be available.
            • maxx-automotive
              • Apr 2006
              • 87
              Hello,
              last call on the GB: closing date for placing orders is approaching. We will be processing the last orders and shipping into March.
              btw there were some questions re S54 installs---there are custom e30 and e36 version s54 airbox fuer use in those chassis.
              • nauqneyugn
                • Oct 2012
                • 201
                Boo just saw this, too bad I missed out.
                • Dussen
                  • 660
                  I know this is closed but what would it cost to upgrade my Alpha-N to the new version from the original version?
