Redline 75/140NS Diff Oil + LSD Friction Modifier
  • funcrew
    • Jun 2007
    • 1223
    The 3.73LSD on my cabrio was working great with 64K on it since new, but I was looking for even more lockup and the 20-year-old oil needed changing anyway for maintenance.
    I drained the diff and filled it with Redline 75/140NS, which does NOT have the LSD friction modifier pre-added. The Redline instructions say, in summary, to slowly add friction modifier until you get down to a level of lockup that you can live with.
    Per Redline instructions, I added one ounce of LSD friction modifier.
    Went for a test drive and the LSD ground and chattered moderately. Again per Redline instructions, I added one more ounce of friction modifier and test drove again. This time it was perfect; nice and smooth; no grinding, no chattering, but the LSD is so tight that it squeals a bit on slow turns with only the slightest throttle pressure. The LSD feels great, and it's easier to kick the tail out.
    Highly recommended.
    BTW Redline says that race cars often don't use any friction modifier at all; they live with the harshness to get higher lockup.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    i always assumed that the friction modifier made it have better lock up, so what i'm getting is that all it does is make it more smooth?
    • kenika65
      • Aug 2007
      • 1336
      hum ok good info.
      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      • funcrew
        • Jun 2007
        • 1223
        The "NS" version of the product does not have friction modifier & provides the greatest lockup, but also the most chatter.
        The regular version of the product has plenty of friction modifier & gives less lockup but more smoothness.
        -Dr. Paul Forrester
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          i see, gotcha. now it all makes since that my diff was having a chatfest when i was using the redline shockproof. driving around parkling lots was really annoying and embarassing, especially having a lady in the car. "my car isn't falling apart i swear"
          • funcrew
            • Jun 2007
            • 1223
            UPDATE: Not a fault of the product, but - My diff seals for the output shafts were seeping just a smidge. Once the synthetic oil went in, they let go in just a few months. I'm now a believer (I ignored the R3V old-timers' warnings) that synth fluids and 20-year-old rubber seals don't work well together. Same thing happened to the transmission (now fixed) and oil cooler thermostat (now fixed).
            If I had another E30, I would just run old-style dinosaur oil in everything unless I changed the seals first.
            -Dr. Paul Forrester
            • SamE30e
              • Sep 2007
              • 4319
              So it would be a good idea to change the seals before adding this?
              1985 325e 2.8 Turbo VEMS
              • funcrew
                • Jun 2007
                • 1223
                If your diff has no leaks at all - if the output flanges are totally clean on the bottom, you might try running the synthetic fluid with the old seals. But keep looking for signs of seepage. There's a nice kit for diff seals and bushing, including 2 quarts of redline here:
                It's the redline fluid that already has the friction modifier, but unless you're racing the car, I think that's fine. The re-seal package is a great deal.
                -Dr. Paul Forrester
                • DiscoE30
                  • Nov 2016
                  • 2
                  Updated link for Red Line Limited-Slip Friction Modifier
                  BTW, Harrison Motorsports updated their website and the link to Diff Reseal is
                  http://www.harrisonmotorsports.com/p...al-reseal-kit/
                  The link to Parts & Product is now http://www.harrisonmotorsports.com/parts/
                  Hope that helps.
