Feeler:Audiophile Door Speaker Enclosure
  • aznbo187
    • Mar 2008
    • 223
    We've all experience the lack of mid-bass from the factory kick panels, and even with upgraded 5.25"/6.5" components it falls severely short of their capabilities and what good sound quality should be. It's non-existent with the factory speakers, and a minimal upgrade with even pricey components. This goes back to the emphasis on how important installation and location is, over expensive speakers.
    Not only that but for those that want to maintain an age-correct and clean feel in the E30 know that to even get a speaker mounted is half the battle. Practically functionless hood release lever, obstructing glove box, unsightly holes in the factory panels, awkward floating speaker on door card, etc.
    There is an option to get something similar made in the UK but parts cost alone is over $300 as someone inquired, and that's without the shipping costs. Plus I'm not sure if they are in business anymore though.
    I'm planning to have a pair of speaker pods made to house a set of 6.5" components by a fabricator who designs applications for IASCA (SQ Audio Competition) events with over 10 years of experience. He has actually done mainly BMW's, and owns one himself which is another plus.
    These speaker pods will be in place of the map pocket by the bottom corner. They will be a composite fiberglass with reinforced backing to make sure they are sturdy enough. I believe there will be an option to retain most of the map pocket but obviously the door card will have to have a small cutout to allow the speaker magnet to breathe, if applicable, and also allow a properly sized enclosure. This is also key to solid mid-bass.
    We will also test various angles to engineer the enclosure to point in the correct direction as well as making sure it's compatible with a wide array of different drivers.
    For those interested in actually hearing some mid-bass than just blaring loud tweeters, this audio upgrade is for you. Mounting the mid-bass speakers correctly will dramatically improve sound quality over the in-effective stock location that fires them at your ankles!
    Here are some question I'm not completely sure about which could help make this product develop a bit quicker. I realize the sedan front doors are shorter than the coupes, but are the map pockets interchangeable?
    Is the functionality of the map pockets important to everyone? The fabricator did mention the use of the map pocket cavity to allow a poly-fill storage pocket to help the speaker "see" a bigger enclosure area, thus a more efficient and better sound.
    I did read that the door skeletons vary between early and late model cars. Is there a difference at that location where the speaker will mount? (front corner of map pocket)
    If there is a difference I may need a test fitter to come to the fabricator to sample the prototype which will be in Anaheim, CA.
    A few more details:
    As far as I know, this should be a direct bolt on replacement panel, except the hole that needs to be trimmed for the magnet. The aim is to place the speaker mount as far away from the panel so the least amount has to be trimmed and the least amount in the way of the glass rail itself it present, of course we will make sure it doesn't become an eye-sore.
    Pricing is not known yet as it depends on the quantity and the actual complexity of the piece, but I'm aiming to keep it within $200. I will open up deposits of $20 for those that are serious as each batch is limited to 15 units. Of course, should the final price be out of your range, a full refund will be applied.
    I'm so certain about the improvement over the existing sound that if your not satisfied with the sound within the first month, I will also offer a full refund.
    Lastly, once I have a complete working setup, anyone interested in a demo before hand may feel free to schedule a listening demo local to me.
    On a final note, I've attached a picture of the UK version which is what we are modeling ours after, but not as rounded to maintain an the factory flow and look. Again, this is ONLY an example picture.
    Excuse the long post, I just wanted to shed as much detail as I could. If you know you are interested and are ready to place a $20 deposit, you can simply send it to flydealz@gmail.com. Remember, at this point the deposits are refundable if pricing should vary vastly from what we estimated, or should the final part not fit your car.
    Interested & ready with $20 Deposit
    1. mbonder
    2. xphiledan
    3. einstein57
    4. jean
    5. dnove89
    6. ikkitousen (Deposit Received)
    7. cong405
    8. ninjaotter (3-5 sets)
  • drumad
    • Aug 2009
    • 1700
    if you can integrate the tweeter into the panel and have it staged properly, I'd buy these vs fabbing my own
    I'd much rather have the mid and the tweeter mounted together.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • mbonder
      • 2255
      I'm interested. To answer a few of your questions:
      Everything mounts in the same location early and late model.
      The map pockets are the same between all models.
      I don't really care about having use of the map pockets if the sound is worth the loss of space.
      Matt
      • NC325iC
        • Mar 2004
        • 6565
        =interested as long as i dont have to cut my door panel, im not into cutting HT doorpanels
        • sweetride01
          • Apr 2004
          • 713
          Not a bad value. It was more than $400 to have my door panels fibreglassed. And I'm also using the stock "mirror" tweeter location, which works fairly well.
          For $200 I would probably have bought the pods you're offering, it would have saved me so much effort and eventual financial outpouring...
          Moving sale: Everything Must Go!
          FS: 2001 740iL Sport, low mileage..... SOLD
          FS: 1990 Mtec II 325iS, $12,0K OVNO
          FS: 2003 Honda Odyssey EX-L Navi..... SOLD
          FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
          FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
          Extreme 325iS (well, slowly getting there, anyway)......
          Almost too many mods to list ;-)
          • xphiledan
            • 706
            very interested... keep the map pockets. interior storage on e30's are so scarce!
            • mbonder
              • 2255
              Just one more reason to leave all your crap at home!
              • europeanplates
                • Jun 2005
                • 1607
                What are these made out of?
                Tyler
                http://www.europeanplates.com Build and Preview plates
                R3V Discount Code = R3V2012
                • E30Nova
                  • 1546
                  Agreed. I want better sound quality, but I like having door pockets.
                  Matt
                  Matt
                  I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                  Originally posted by kronus
                  try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                  This is like a reverse build thread; it starts out nice and gets shitty.
                  • george graves
                    • 20003
                    I might be interested. I'd be very interested in Luke's opinion actually.
                    ditto: what are these made out of?
                    Originally posted by Matt-B
                    • einstein57
                      • Jun 2007
                      • 10780
                      Im interested. Cost me more then $200 to build my subwoofer enclosure. Fiberglass is expensive when you don't know what your doing. Lol
                      www.gecoils.com
                      • aznbo187
                        • Mar 2008
                        • 223
                        That's correct, they are a composite fiberglass. Some type of material is added to the fiberglass mixture itself to make sure it's completely reliable and a solid piece. It's a trade secret they have been using for years on all their fg builds so I can't really find out what they use. Like mentioned before, if your not happy within the first month with the product, you can return or exchange it.
                        Ideally, the door card would need a small hole for the magnet to pass through. This would also allow the driver to breathe properly utilizing the door cavity itself as an enclosure. This allows us to retain a map pocket, with the most use-able sound quality. Although, talking to Luke recently too I'm fairly sure that simply moving the location alone is an upgrade itself.
                        Let's get a list going to keep track. Once we reach around 15 people I will drop my car off for the R&D and also start collecting the deposits.
                        1. mbonder
                        2. xphiledan
                        3. einstein57
                        Any other questions, feel free to ask and I will try my best to get them answered. I didn't add everyone interested as there were some concerns that you guys weren't sure about which I addressed in this post. Please add yourself to the list if you are interested.
                        • europeanplates
                          • Jun 2005
                          • 1607
                          It would be intersting to see how think the baffle is where the speaker mounts. This make a large impact on sound. A nice two peice co-axial would sound great in that location.
                          Tyler
                          • Jean
                            • 18228
                            Count me in. Would like to see maybe drawings of what it will actually look like, since it won't be the same as pictured above.
                            • dnova89
                              • Aug 2009
                              • 851
                              Interested. Damn, now I HAVE to get an alarm if I do this haha.
                              -Darius (aka DiscoDoughnuts on other forums)
                              dude man bro...
