42 Draft Designs Spacers and Adapters
  • 8380 Labs
    • Oct 2006
    • 2990
    #196
    keep em comin!
    8380 Laboratories
    M3 Champs Poster
    • mkcman17
      • Jul 2010
      • 8240
      #197
      after having these on for a bit over a month, i have one question/concern.
      i'm not sure if i'm the only person that had an issue with this, but the nuts tightened themselves to well over 100 lbs/ft after first fitment (i torqued them with a wrench to 75-80 lbs/ft) i don't typically have access to an impact gun, so i attempted to remove them with a 6-point/breaker and ended up nearly rounding off about half the nuts (mixture of very shallow nuts and deep center wheels). i went ahead and purchased some 75mm nuts from motorsport tech (problem solved), but i was a little concerned with how soft the nuts were considering their shallow nature.
      1989 LN106 Hilux / 3.0TD SFA
      1974 2002tii / stock
      2002 IS300 / 5spd LSD
      • 8380 Labs
        • Oct 2006
        • 2990
        #198
        i haven't heard from anyone else who had that experience - i'll pass that onto the 42 draft guys, thanks.
        8380 Laboratories
        M3 Champs Poster
        • mkcman17
          • Jul 2010
          • 8240
          #199
          :up:
          • Jszy25
            • 352
            #200
            Payment sent.
            91' 318is - OBDI M52/ZF swap w/ S50 cams
            • 8380 Labs
              • Oct 2006
              • 2990
              #201
              Originally posted by mkcman17
              :up:
              here's 42 draft's response when i passed your issue onto them:
              "We verified that those were the correct lugs, they should not have rounded out like that. You may need to use a deeper socket to get the entire lug nut head in the socket. The socket might have been bottoming out on the stud on the adapter so it could only grab onto half of the head or so which could cause it to weaken and round. With the entire head of the nut in the socket it will not round though."
              8380 Laboratories
              M3 Champs Poster
              • deadlydave
                • Sep 2009
                • 44
                #202
                This has probably been asked before, but do the 4x100 20 and 25mm spacers bolt to the hub, and then use a 2nd set of bolts to attach the wheel? Those are some fine looking spacers and the price can't be beat. It looks like that's how the 5-lug ones are but I couldn't find pics of the 4-lug ones.
                Thanks in Advance,
                -Dave
                1991 BMW 318is, mild SOLD | 1996 Subaru Impreza Wagon(STi V2 replica), inferno spicy
                • 8380 Labs
                  • Oct 2006
                  • 2990
                  #203
                  the standard spacers (4x100, 5x100, etc. etc.) come with longer lug bolts and sandwich between the wheel and hub - they are not "adapter style" spacers that bolt to the hub first.
                  8380 Laboratories
                  M3 Champs Poster
                  • TrippinBimmer
                    • Feb 2011
                    • 182
                    #204
                    Can we get it with Adapter Style? And also different hub bore? I have some Works Emotion CR Wheels from my Civic days I like to use....
                    • 8380 Labs
                      • Oct 2006
                      • 2990
                      #205
                      yup, that's not a problem - email me at info@8380labs.com and i'll get you set up, thanks!
                      8380 Laboratories
                      M3 Champs Poster
                      • quillbro
                        • 369
                        #206
                        Originally posted by slowe34
                        Got mine yesterday and mounted up!
                        Took a bit of time to get the first one on, but once I figured out how to get that kidney thing lined up it was a breeze.
                        mmmm style fives
                        whats size are those wheels?
                        • 8380 Labs
                          • Oct 2006
                          • 2990
                          #207
                          Those are 16x8 et20 with 205/45s.
                          8380 Laboratories
                          M3 Champs Poster
                          • Dj Buttchug
                            • Jun 2010
                            • 7624
                            #208
                            aight, im in the mix on these. Pm sent
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • 8380 Labs
                              • Oct 2006
                              • 2990
                              #209
                              replied.
                              up!
                              8380 Laboratories
                              M3 Champs Poster
                              • ACHTUNG
                                • May 2005
                                • 2397
                                #210
                                Do you make an adapter that's 4x100 to 4.114.3 (4x4.5)? If so, what widths do you offer with this configuration? thanks
                                1989 US E30 Cammed S52
                                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
