keep em comin!
42 Draft Designs Spacers and Adapters
after having these on for a bit over a month, i have one question/concern.
i'm not sure if i'm the only person that had an issue with this, but the nuts tightened themselves to well over 100 lbs/ft after first fitment (i torqued them with a wrench to 75-80 lbs/ft) i don't typically have access to an impact gun, so i attempted to remove them with a 6-point/breaker and ended up nearly rounding off about half the nuts (mixture of very shallow nuts and deep center wheels). i went ahead and purchased some 75mm nuts from motorsport tech (problem solved), but i was a little concerned with how soft the nuts were considering their shallow nature.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSD
Originally posted by mkcman17 View Post:up:
"We verified that those were the correct lugs, they should not have rounded out like that. You may need to use a deeper socket to get the entire lug nut head in the socket. The socket might have been bottoming out on the stud on the adapter so it could only grab onto half of the head or so which could cause it to weaken and round. With the entire head of the nut in the socket it will not round though."
This has probably been asked before, but do the 4x100 20 and 25mm spacers bolt to the hub, and then use a 2nd set of bolts to attach the wheel? Those are some fine looking spacers and the price can't be beat. It looks like that's how the 5-lug ones are but I couldn't find pics of the 4-lug ones.
Thanks in Advance,
-Dave1991 BMW 318is, mild SOLD | 1996 Subaru Impreza Wagon(STi V2 replica), inferno spicy
Originally posted by 8380 Labs View Postthe standard spacers (4x100, 5x100, etc. etc.) come with longer lug bolts and sandwich between the wheel and hub - they are not "adapter style" spacers that bolt to the hub first.
