42 Draft Designs Spacers and Adapters
 It depends how much camber you have at your given ride height. When I'm on level ground completely aired out, the fenders are resting on the tires.
 I can tuck the rear only when parked on a slope. This is stock camber settings in the rear and -3 degrees in front. I'm not sure how others get away with a final offset of ET0 without major modification.Comment
 any issues with running spacers on one side only?... i am considering getting 20mm for drivers side only..?
 87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzitComment
 nevermind on th e spacer on one side question.. just reread the rulebook and spacers must be used in"matching pairs on each axle"... I NEED 10mm on each wheel but am concerned about lack of wheelcentricity on th racecar.
 168 cm with a leeway for 5mm.... max width front and rear...
 15 is supposed perfect offset and my 8 wheels are 25 koseis
 2014 Alpine White 335i MSport
 (Daily Driver)
 Full Mperformance Aero
 KW V2 Coilovers
 VRSF Catless DownpipesComment
