Damn really great looking product once i save up money il order a set for sure! gotta make these lorinsers fit
					42 Draft Designs Spacers and Adapters
 can I ask a stupid question please?
 When looking for 5x120 wheels, assuming each spacer is 18mm thick, does that mean I need to look for wheels that are 18mm less in ET?
 Say I was after an 'original E30 equipment' fitment at ET20 in a 7inch wheel. To get that same fitment I now need to look for an ET38 wheel in 7inch width?
 is it that SIMPLE?
 thanks88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
 90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro ExpertsComment
 sounds good, we'll be here.
 your math is correct, but in reality you've got a little more wiggle room.can I ask a stupid question please?
 is it that SIMPLE?
 thanks
 the stock widths+offsets usually leave some room to move the wheels outward without causing much of a problem.
 if you ran 205/50s on 15x7 et20 with 18mm adapters, you'd be able to get away with a good fender roll to make that setup work.Comment
 During a google search, I foun that the e30 center bore is 57cm, whereas e36 have a center bore of 72.5; will the spacers accommodate the e30 bore as well as the wheel bore for e36 wheels?Needs: Working window regulators for my E30 sedan;)Comment
 east coasters get your wheel setups on for bimmerfest east this month! :pComment
 I'm interested in getting a pair of 5mm spacers that are hubcentric to my 74.1mm wheels. Also the inner bore needs to be flat instead of tapered because of the thickness of my BBK hats.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 www.gecoils.com
 My euro 316 project Transaction FeedbackComment
 that shouldn't be a problem, go ahead and send me an email (info@8380labs.com) with those specs (bolt pattern too) and i'll get you a quote for that next week after i check with the guys.Comment
