got it, thanks brian. :)
42 Draft Designs Spacers and Adapters
i'm told by the end of next week the pending 4 > 5 lug adapter orders will be completed and shipped.Comment
Will they have 4x100 to 5x120 20mm? I would like soonish.SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275Comment
yes, they do have 4x100 > 5x120 in 20mm, we've already taken a couple orders for them.
they're doing a big run of 4 > 5 lug this week so you're in good shape.Comment
i need to update the first post, as there's been a change.
i've managed to convince the 42 draft guys to revisit the minimum thickness issue and they've concluded 18mm is good to go.
pricing for a full set is $400 + shipping.
email us at info@8380labs.com and i'll get you set up if you'd like to order.
i've emailed all pending orders to ask if they want to change their orders to 18mm.Comment
weather's getting nicer - dreams of wheel setups dancing in our heads...:pComment
they can do 18/20/25.
realistically, since you've got an option within 2-3mm in either direction you should be good to go. if you're concerned 25mm is too much, 20mm will do the trick fine and there will be very little difference visually.Comment
all pending orders have shipped, an email with tracking info was sent as well. :DComment
not a bad idea - these are going to be easier to use and safer as well.Comment
