42 Draft Designs Spacers and Adapters
  • TYBG
    • May 2012
    • 143
    #226
    Damn really great looking product once i save up money il order a set for sure! gotta make these lorinsers fit
    • burkey001
      • Feb 2011
      • 608
      #227
      can I ask a stupid question please?
      When looking for 5x120 wheels, assuming each spacer is 18mm thick, does that mean I need to look for wheels that are 18mm less in ET?
      Say I was after an 'original E30 equipment' fitment at ET20 in a 7inch wheel. To get that same fitment I now need to look for an ET38 wheel in 7inch width?
      is it that SIMPLE?
      thanks
      88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
      90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
      • 8380 Labs
        • Oct 2006
        • 2990
        #228
        sounds good, we'll be here.
        is it that SIMPLE?
        thanks
        your math is correct, but in reality you've got a little more wiggle room.
        the stock widths+offsets usually leave some room to move the wheels outward without causing much of a problem.
        if you ran 205/50s on 15x7 et20 with 18mm adapters, you'd be able to get away with a good fender roll to make that setup work.
        8380 Laboratories
        M3 Champs Poster
        • owenf
          • Jul 2012
          • 1
          #229
          how much for 4 18mm 4x100 to 5x120 adapters shipped to ireland
          • 8380 Labs
            • Oct 2006
            • 2990
            #230
            PM sent.
            8380 Laboratories
            M3 Champs Poster
            • 8380 Labs
              • Oct 2006
              • 2990
              #231
              8380 Laboratories
              M3 Champs Poster
              • Mr_P
                • Jul 2012
                • 13
                #232
                Do you ship to Aus? - Might be easier than trying to find a set of 17" 4x100 wheels here!
                Cheers
                • 8380 Labs
                  • Oct 2006
                  • 2990
                  #233
                  worldwide shipping available, yup. ;)
                  8380 Laboratories
                  M3 Champs Poster
                  • 8380 Labs
                    • Oct 2006
                    • 2990
                    #234
                    8380 Laboratories
                    M3 Champs Poster
                    • usingthejohn
                      • 76
                      #235
                      During a google search, I foun that the e30 center bore is 57cm, whereas e36 have a center bore of 72.5; will the spacers accommodate the e30 bore as well as the wheel bore for e36 wheels?
                      Needs: Working window regulators for my E30 sedan;)
                      • 8380 Labs
                        • Oct 2006
                        • 2990
                        #236
                        east coasters get your wheel setups on for bimmerfest east this month! :p
                        8380 Laboratories
                        M3 Champs Poster
                        • 8380 Labs
                          • Oct 2006
                          • 2990
                          #237
                          top
                          8380 Laboratories
                          M3 Champs Poster
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            #238
                            8380 Laboratories
                            M3 Champs Poster
                            • einstein57
                              • Jun 2007
                              • 10780
                              #239
                              I'm interested in getting a pair of 5mm spacers that are hubcentric to my 74.1mm wheels. Also the inner bore needs to be flat instead of tapered because of the thickness of my BBK hats.
                              www.gecoils.com
                              • 8380 Labs
                                • Oct 2006
                                • 2990
                                #240
                                that shouldn't be a problem, go ahead and send me an email (info@8380labs.com) with those specs (bolt pattern too) and i'll get you a quote for that next week after i check with the guys.
                                8380 Laboratories
                                M3 Champs Poster
