Sent from my iPhone using Tapatalk Pro
Shadowline Motorsport - LED Bulbs & Accessories
The R8 H1 kit will fit euro smileys no problem correct?Singer Vehicle Design.
Quan@singervehicledesign.com
Originally posted by cali_e30 View PostThe R8 H1 kit will fit euro smileys no problem correct?
Yes sir! We test fit all of the products we offer.
Thanks
Originally posted by Staszek View PostWill the R8’s fit behind the bulb cap in the Depo high beams?
I think they are still a little bit too long for the caps but I will test and confirm. Most of the bulbs on the market are too big so I didn't think to test the bulb caps but these bulbs are a lot smaller so it may be close. Worst case, the cap will have to be modified.
Thanks,
Bryon
Originally posted by djmossm42 View PostI think they are still a little bit too long for the caps but I will test and confirm. Most of the bulbs on the market are too big so I didn't think to test the bulb caps but these bulbs are a lot smaller so it may be close. Worst case, the cap will have to be modified.
Thanks,
Bryon
Shadowline Motorsport - LED Headlight Bulbs Starting @ $65/Set!
Originally posted by Staszek View PostThanks for testing!
No problem!
I did a quick fit test and it looks like it will fit under the highbeam cap but the bulb driver is not detachable so you would still need to cut a hole or slot to loop the cable out and back in. Most of the cable can probably be coiled neatly around the inner wall of the cap.
It was hard to get a picture on the back of the housing so I took a side by side pic so you can get a good size reference.
The only concern may be if the fan can move enough air in the cap.
Upon closer inspection of the cap, it is already setup for cable management. However my caps came with Depos and not sure if the Euro Hellas are the same.
Sent from my iPhone using Tapatalk ProLast edited by djmossm42; 08-21-2018, 07:19 AM.
When do we expect to see this upcoming batch ship?Singer Vehicle Design.
Originally posted by cali_e30 View PostWhen do we expect to see this upcoming batch ship?
I was just about send an update! The bulbs have been shipped from the manufacturer and should be arriving this Friday 8/24/18. So orders will ship no later than Monday.
Thanks
