R8 LED Headlight Bulbs - 4200LM/Bulb
$64.99
More Details!
Improving upon the design of the R7, the R8 amps up the output to 4200LM!
The R8 is one of the most compact bulbs on the market. It features a 1mm thick shaft that greatly reduces dark spots and increases effective light output. By positioning the LEDs as close to the original focal point as possible you can expect less glare and better performance than most other LED bulbs. Our bulbs come with the larger higher output Y19 Korean LED chips.
Key Features
- Korean Y19 chips are arranged in two 1x3 arrays 180° apart.
- Compact size comparable to standard bulb
- Highly effective lumen output @ 4200LM/Bulb. Luminous point is only 1.00 mm
- IP68 water/dust proof
- All metal housing
- Available in 3000K,5000K,6000K
- 24 Month Warranty
What's in the package?
- 1 Set = 2 bulbs with built-in drivers
_________________________________________________
R7 LED Headlight Bulbs, 3600LM/Bulb - 5700K
$64.99
More Details!
The R7 introduces a brand new design that delivers high efficiency in a small package. Don't let the lower lumen rating put you off, these bulbs are bright and effective.
Key Features
- Genuine Phillips ZES chips are arranged in two 1x3 arrays 180° apart.
- Fanless design
- Highly effective lumen output @ 3600LM/Bulb. Luminous point is only 1.25mm
- All metal base and collars
- Available in 5700K (White)
- 24 Month Warranty
R6 LED Headlight Bulbs, 5800LM/Bulb/6000K Only
$54.99
More Details!
The R6 builds on the solid foundation of the R4 and adds 2 more banks of LEDs for a total of 4! Since the light is more evenly spread across the reflector, you can expect a bright and full beam and a nice hot spot! The compact design makes converting from halogen to LED a simple task for most applications.
Key Features
- Fanless design
- Compact size
- High Lumen output @ 5800LM/Bulb
- LED chips are arranged in a 1x4 array every 90° around the shaft.
- Only Available in 6000K at this time
- 24 Month Warranty
- 1 Set = 2 bulbs with drivers (ballasts)
- Grommets for advanced retrofits
- Quick Install booklet
R4 LED Headlight Bulbs, 4800LM/Bulb, 3000K/4300K/5000K/6000K/8000K
Videos:
CLEARANCE SEE WEBSITE FOR CURRENT PRICE
More Details!
The R4 LED bulbs are very bright and do not produce any EMI (radio interference), they do not have a visible flicker, and have a lifespan >30,000 hours. The design is based on the bulb type you are replacing so the LEDs are positioned in the same relative location to the reflector as the standard bulb for your headlights. The most interesting feature is the lack of a fan which is a common point of failure in other LED kits. Instead, the R4 uses a copper braided heatsink.
Key Features
- Fanless design
- Compact size
- High Lumen output @ 4800LM/Bulb
- Base rotates 90° for best light emittance (Select bulb types only)
- 5 color temperatures available (3000K, 4300K, 5000K, 6000K, 8000K)
- Built in reflector to help spread and direct light towards the headlight reflector
- 24 Month Warranty
ACCESSORIES
H4/H1 Inline Relay Adapter - Male H4 to H1 w/ Bi-Xenon Shield Connector - Pair
$49.99
More Details!
Are you are planning to convert from sealed beams to HID or LED bulbs? Did you complete the conversion and realize your low beams no longer stay engaged when you activate the high beam? This is because the original sealed low beam is dual filament with Hi and low built in. You will find write-ups on using a jumper wire between the relays but you may not want to alter the fuse box or potentially jump the wrong terminals which could cause serious damage.
This plug-n-play relay will keep the low beam on while the high beam is engaged. It also has a standard shield connector which is compatible with most bi-xenon projectors including our upcoming bi-xenon conversion kit.
For cars with original H4 Connector
Sold in pairs.
Key Features
- Plug & Play
- Easy to return to stock
- 24 Month Warranty
- 1 Set = 2 plug in relays with H1 pigtails
Illuminated Power Window Switch (PAIR) - 61311381205/61311377905 - E23, E24, E28, E30
$11.99
More Details!
Aftermarket power window switch, replaces BMW part numbers 61-311-381-205 and 61-311-377-905
Sold In Pairs.
Key Features
- Direct Replacement
- Easy installation
- 24 Month Warranty
- 1 Set = 2 switches
SHIPPING
Orders to US Shipping addresses are shipped via USPS Priority at reduced rates.
Orders to Canada will be shipped via USPS International Parcel at reduced rate
TAX
California residents pay 10%
ORDER PROCESS
1. Order is received
2. We check local inventory for order, if available your order ships within 24 hours.
2. If your order can not be fulfilled from our local inventory we will forward the order to manufacturer
3. Production begins (Allow ~10 days)*
4. Order is shipped to us, usually received within 3 days.
5. Order is shipped to customer(s)
* ALL orders requesting color temperatures other than 6000K require production if we don't have it in local inventory. There is about a 7-10 business day lead time from time you place your order to when you receive them. Any changes need to be made within 48 hours after the order was placed.
WARRANTY
All bulbs come with a 24 Month Warranty
REVIEWS
R6 LED Bulb review by Jeff (Redsubdivisions)
IMPORTANT INFORMATION
- For E30 Euro assemblies requiring H1 Bulbs, the small caps with socket may need to be modified. You can follow this write-up from one of our customers http://store.shadowlinemotorsport.co...ights_b_2.html.
- If your car is equipped with sealed beam headlights, we recommend you convert to US Hella/Bosch projector assemblies, Euro Hella projector assemblies, or an aftermarket equivalent made by DEPO.
LED BULBS ARE ONLY RECOMMENDED FOR HEADLIGHT SYSTEMS DESIGNED FOR HIGH INTENSITY LIGHT SOURCES, SUCH AS HID PROJECTORS WITH PROPER CUTOFF SHIELDS. CHECK YOUR LOCAL LAWS REGARDING LED BULBS FOR USE ON PUBLIC ROADS BEFORE PURCHASING.
Follow Us On Instagram
$64.99
More Details!
Key Features
- All metal housing
- 24 Month Warranty
$64.99
More Details!
Key Features
- Fanless design
- 24 Month Warranty
$54.99
More Details!
Key Features
- Fanless design
- Compact size
- 24 Month Warranty
Videos:
More Details!
Key Features
- Fanless design
- Compact size
- 24 Month Warranty
ACCESSORIES
$49.99
More Details!
Sold in pairs.
Key Features
- Plug & Play
- 24 Month Warranty
$11.99
More Details!
Sold In Pairs.
Key Features
- Easy installation
- 24 Month Warranty
SHIPPING
TAX
ORDER PROCESS
WARRANTY
REVIEWS
