Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Shadowline Motorsport - LED Bulbs & Accessories
    R8 LED Headlight Bulbs - 4200LM/Bulb
    $64.99
    More Details!
    Improving upon the design of the R7, the R8 amps up the output to 4200LM!
    The R8 is one of the most compact bulbs on the market. It features a 1mm thick shaft that greatly reduces dark spots and increases effective light output. By positioning the LEDs as close to the original focal point as possible you can expect less glare and better performance than most other LED bulbs. Our bulbs come with the larger higher output Y19 Korean LED chips.
    Key Features
    - Korean Y19 chips are arranged in two 1x3 arrays 180 apart.
    - Compact size comparable to standard bulb
    - Highly effective lumen output @ 4200LM/Bulb. Luminous point is only 1.00 mm
    - IP68 water/dust proof
    - All metal housing
    - Available in 3000K,5000K,6000K
    - 24 Month Warranty
    What's in the package?
    - 1 Set = 2 bulbs with built-in drivers
    _________________________________________________
    R7 LED Headlight Bulbs, 3600LM/Bulb - 5700K
    $64.99
    More Details!
    The R7 introduces a brand new design that delivers high efficiency in a small package. Don't let the lower lumen rating put you off, these bulbs are bright and effective.
    Key Features
    - Genuine Phillips ZES chips are arranged in two 1x3 arrays 180 apart.
    - Fanless design
    - Highly effective lumen output @ 3600LM/Bulb. Luminous point is only 1.25mm
    - All metal base and collars
    - Available in 5700K (White)
    - 24 Month Warranty
    R6 LED Headlight Bulbs, 5800LM/Bulb/6000K Only
    $54.99
    More Details!
    The R6 builds on the solid foundation of the R4 and adds 2 more banks of LEDs for a total of 4! Since the light is more evenly spread across the reflector, you can expect a bright and full beam and a nice hot spot! The compact design makes converting from halogen to LED a simple task for most applications.
    Key Features
    - Fanless design
    - Compact size
    - High Lumen output @ 5800LM/Bulb
    - LED chips are arranged in a 1x4 array every 90 around the shaft.
    - Only Available in 6000K at this time
    - 24 Month Warranty
    - 1 Set = 2 bulbs with drivers (ballasts)
    - Grommets for advanced retrofits
    - Quick Install booklet
    R4 LED Headlight Bulbs, 4800LM/Bulb, 3000K/4300K/5000K/6000K/8000K
    Videos:
    https://vimeo.com/170703152
    https://vimeo.com/170732989
    https://vimeo.com/170733209
    CLEARANCE SEE WEBSITE FOR CURRENT PRICE
    More Details!
    The R4 LED bulbs are very bright and do not produce any EMI (radio interference), they do not have a visible flicker, and have a lifespan >30,000 hours. The design is based on the bulb type you are replacing so the LEDs are positioned in the same relative location to the reflector as the standard bulb for your headlights. The most interesting feature is the lack of a fan which is a common point of failure in other LED kits. Instead, the R4 uses a copper braided heatsink.
    Key Features
    - Fanless design
    - Compact size
    - High Lumen output @ 4800LM/Bulb
    - Base rotates 90 for best light emittance (Select bulb types only)
    - 5 color temperatures available (3000K, 4300K, 5000K, 6000K, 8000K)
    - Built in reflector to help spread and direct light towards the headlight reflector
    - 24 Month Warranty
    ACCESSORIES
    H4/H1 Inline Relay Adapter - Male H4 to H1 w/ Bi-Xenon Shield Connector - Pair
    $49.99
    More Details!
    Are you are planning to convert from sealed beams to HID or LED bulbs? Did you complete the conversion and realize your low beams no longer stay engaged when you activate the high beam? This is because the original sealed low beam is dual filament with Hi and low built in. You will find write-ups on using a jumper wire between the relays but you may not want to alter the fuse box or potentially jump the wrong terminals which could cause serious damage.
    This plug-n-play relay will keep the low beam on while the high beam is engaged. It also has a standard shield connector which is compatible with most bi-xenon projectors including our upcoming bi-xenon conversion kit.
    For cars with original H4 Connector
    Sold in pairs.
    Key Features
    - Plug & Play
    - Easy to return to stock
    - 24 Month Warranty
    - 1 Set = 2 plug in relays with H1 pigtails
    Illuminated Power Window Switch (PAIR) - 61311381205/61311377905 - E23, E24, E28, E30
    $11.99
    More Details!
    Aftermarket power window switch, replaces BMW part numbers 61-311-381-205 and 61-311-377-905
    Sold In Pairs.
    Key Features
    - Direct Replacement
    - Easy installation
    - 24 Month Warranty
    - 1 Set = 2 switches
    SHIPPING
    Orders to US Shipping addresses are shipped via USPS Priority at reduced rates.
    Orders to Canada will be shipped via USPS International Parcel at reduced rate
    TAX
    California residents pay 10%
    ORDER PROCESS
    1. Order is received
    2. We check local inventory for order, if available your order ships within 24 hours.
    2. If your order can not be fulfilled from our local inventory we will forward the order to manufacturer
    3. Production begins (Allow ~10 days)*
    4. Order is shipped to us, usually received within 3 days.
    5. Order is shipped to customer(s)
    * ALL orders requesting color temperatures other than 6000K require production if we don't have it in local inventory. There is about a 7-10 business day lead time from time you place your order to when you receive them. Any changes need to be made within 48 hours after the order was placed.
    WARRANTY
    All bulbs come with a 24 Month Warranty
    REVIEWS
    R6 LED Bulb review by Jeff (Redsubdivisions)
    IMPORTANT INFORMATION
    - For E30 Euro assemblies requiring H1 Bulbs, the small caps with socket may need to be modified. You can follow this write-up from one of our customers http://store.shadowlinemotorsport.co...ights_b_2.html.
    - If your car is equipped with sealed beam headlights, we recommend you convert to US Hella/Bosch projector assemblies, Euro Hella projector assemblies, or an aftermarket equivalent made by DEPO.
    LED BULBS ARE ONLY RECOMMENDED FOR HEADLIGHT SYSTEMS DESIGNED FOR HIGH INTENSITY LIGHT SOURCES, SUCH AS HID PROJECTORS WITH PROPER CUTOFF SHIELDS. CHECK YOUR LOCAL LAWS REGARDING LED BULBS FOR USE ON PUBLIC ROADS BEFORE PURCHASING.
    Follow Us On Instagram
    Wheelwell
    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
    LED Bulb Thread
    R6 LED Review
    Any pics of output?
    Sent from my XT1064 using Tapatalk
    (OO=[][]=OO) For Life
      I will post today
      Sent from my MI 4LTE using Tapatalk
      Wheelwell
      LED Bulb Thread
      R6 LED Review
        Sorry, do these work right out of the box ? or do you need a pre existing HID kit installed ?
        I have the EURO smileys on my car, with NO HID kit in. Just stick bulbs, is this just a bulb upgrade ?
        thank you in advance.
          these look really interesting. any night shots/vids of these in action?
            These are plug n play, they are designed with the same dimensions as the bulb it substitutes. No modifications needed to the housings. It comes with everything you need.
            Euro reps like depos, original bosch or hella Euro projectors use H1
            US projectors use 9006
            Wheelwell
            LED Bulb Thread
            R6 LED Review
              Nice, Thanks for the quick reply.
              Sent from my SM-G900T using Tapatalk
                I just installed them today, so I will get some night shots in a few hours
                Wheelwell
                LED Bulb Thread
                R6 LED Review
                  Night Shots!!
                  Stock E92 328i M Sport, Stock Hid bulbs (Left), My car on the right
                  Opposite wall, lights off
                  Opposite wall, lights on
                  Outside lights off
                  Outside lights on
                  Wheelwell
                  LED Bulb Thread
                  R6 LED Review
                    Thanks for the night shots. What temp/color bulbs are in the video and photos?
                      6000K
                      Wheelwell
                      LED Bulb Thread
                      R6 LED Review
                        Plug and play? Shit, you can't beat that. What bulb would be similar to common HIDs? I am looking to match my E46's stock HID's, preferably without the blue hue that I see in the videos.
                        1989 325i - 2.7i, Holset H1C, 42lb injectors, 14.7 psi, whodwho MS-PNP.
                        2009 X5 - DD Duty
                        2018 VW Atlas - Wife/kiddie/grocery hauler
                          The closest match in color would be the 4300k bulbs, but will lean towards yellow.
                          Based on the bulb guide you need D2S which is an available option.
                          I used 2004 330Ci to look it up. The daytime running light is H7 which I can also get.
                          http://www.sylvania.com/en-us/applic...l=2497&make=13
                          Wheelwell
                          LED Bulb Thread
                          R6 LED Review
                            cool, reserved a few sets.
                              Thank you sir!
                              Wheelwell
                              LED Bulb Thread
                              R6 LED Review
