How much did your swap/ rebuild cost?
    Stock m50 and 5 lug for about a grand
    -Andy
      well in that case, heres the new bugatti veyron
      it has around 1000hp and goes 0-60 in under 3 seconds on to a top speed of over 250mph
      Discover the home of BUGATTI. Experience the incomparable nature of the hyper luxury brand and all its offering. From Molsheim to the racetracks.
        It will be about seven thousand dollars US.
        2300.00 engine s52
        2500.00 labor
        And all the rest for mounts,diff,obd1 stuff,turner chip
        Engine refresh.
        Don't forget CPU. Dme red label 413
        Oil pan, dip stick w/tube, etc..
          2300.00 engine s52
          2500.00 labor
          Engine refresh.
          ouch I could do about 4grand but I dont think I want to drop 7
            if you pay less it's because you did the work your self..... ijs
              It depends if you want NEW or USED parts. For 7k you could have a decently built S52 making great power with new parts. Or for 7k you could build and boost it with used parts. Obviously doing labor by yourself and waiting for parts to show up in the classifieds. I'm in 2.5k with all obd1 swap parts + S52 so far. But that is why building cars is not an investment, but a time consuming hobby for the everyday gear head. The end goal is all determined on what YOU want out of the vehicle.
              Sent from my android, jk fuck android.
              DESTROY GARAGE
              S T R E E T S T Y L E
              @CRISMACSTUDIO
              FREE SHELL, COME GET IT!
                One million pasados.
                Just kidding. I guess the price can vary a lot depending on where you get the engine, what kind of engine it is, how many tools you have, how many tools you break, how many parts you break, how many parts need to be replaced, et cetera. I'm hearing around low thousands. Sounds about right to me.
                -Experience is what you have right after you need it
                  2300.00 engine s52
                  2500.00 labor
                  Engine refresh.
                  $2500 is kind of low to have a professional shop do your install unless you had everything (including exhaust) ready to bolt in, and you didn't care about the cosmetics like engine bay steam cleaning, or preventative maintenance such as engine re-sealing, oil pump nut securing etc.
                  john@m20guru.com
                  Links:
                    Originally posted by F34R View Post
                    Research build threads man, junk yards help with buying the engine. Prices range from 200-6k+
                    This. I'm in the process of going through about every build thread I can find for swap as well as researching the info that is out there. The amount of information out there is enormous but at the same time somewhat overwhelming. So many different opinions and options, it's hard to sort through it.
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                      This is sort of my breakdown:
                      I bought a salvaged 92 325i auto w/ 108k miles: $650 (after paying auction fees)
                      Bought a e30 rolling shell: $800
                      ZF320 trans, clutch, flywheel, pressure plate, and driveline: $450 (craigslist)
                      Refresh parts for trans and motor: $200
                      motor mounts and trans mounts: $65
                      OBD1 manifolds: $100
                      Custom fabricated exhaust: $350
                      S2.93 diff: $200
                      Misc: $300
                      Sold parts from e36 and e30: -$800
                      GRAND TOTAL:$2,315 (I'm 95% done and besides the exhaust and a few other small things, I did all the labor my self)
                      *Still have a full interior to sell out of the E36 (est. value $350)
                      Hope this helps.
                      SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
                        I have been going through and pricing out what I think I'll need. Pretty sure I found a good deal on an engine and some other bits but I'm hoping to keep this around a grand. Fairly basic M50 swap reusing as much as I can.
                        05 Honda Pilot
                        24V swap thread
                          So made a couple of phone calls to some shops in the area about doing this s52 swap I found some reasonable engine tranny options even found a couple of whole donor cars like a 99 m3 runs and drives crashed in side frame damage $3.5k from that car I can get just about everything I need to complete swap including 5lug conversion with exceptions like
                          Oilpan
                          Motor mounts and bracket
                          Brake booster
                          Drive shaft (not sure)
                          Ecu ewe flash out
                          Radiator (not sure)
                          Full custom exhaust
                          Even if I'm forgetting some things those extra parts can't come to more than $2k-$2.5k
                          So far that's around $6k just to estimate plus labor (don't know how many hours this takes) but I estimated this entire process would cost me $7-$8k
                          According to the last shop I spoke to "you smoking crack if you think you can get an s52 swap done between $5k and $8k"
                          Am I smoking crack? $15k-$20k for these swaps? Or are these people buying them for that price on crack? For real what's the deal what should this cost me?
                            We've built three swap cars. The first one was done on a shoe string budget that was around 7k. The two after that? 12k and higher.
                            If you do it yourself then yeh, its cheaper but when you have a professional doing the work the costs go up.
                            The reason is because many parts are bought new. If you really want to cheap out on this stuff you can... but don't expect everything to be great afterwards. Working on an E30 with a swap is no longer as easy as it is with a stock motor.
                            E.G. the blower motor. you have to remove the bloody intake manifold to get to the cowl!! It just makes sense to do things right the first time around!
                              It cost just about 3grand with all the miscelanious if your doing the swap yourself !!!
                                Currently at just over $1700 for the following
                                -M50
                                -G250
                                -driveshaft
                                -E34 oil pan
                                -engine harness
                                -harness adapter
                                -alternator
                                -MAF
                                -DME
                                -New clutch and lightened flywheel
                                -oil pressure gauge
                                - about $250 worth of refresh maintenance bits
                                -Spal pusher fan
                                and some random bits here and there. I could have cut costs here and there and probably found better deals if I really searched but I accounted for an approx $2k budget and I'll be pretty close to it.
                                05 Honda Pilot
                                24V swap thread
