hey guys so at the local junk yard by my house there are 2 engines... idk if they are m50s or m52s.. where is the engine code on the block located so i can figure it out?
found some m50s at junk yard. Where the engine code!!
Visually it's pretty easy to deduce what's what.
Is the intake a straight runner or the smaller curved runners?
What oil filter housing? plastic or steel?
Valve cover plastic or magnesium?
Is there a crank sensor on the front pulley? or is it in the rear of the block on the drivers side below the starter?Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
