Shifter too far forward. What you guys do about it ?
  • e30de89
    • Sep 2006
    • 197
    My shifter is way too far forward is there anything that can be done besides cutting and re welding? I originally thought an s52 with e36 tranny is a direct fit.
    Green 89 325 s52 build: http://www.r3vlimited.com/board/showthread.php?t=280902
  • f4tj0n
    • May 2013
    • 411
    Which shift carrier/selector arm are you using? From the E30 or E36?
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      You might have the shifter turned around 180*. Take it off of the selector rod and flip it. That might fix your problem
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • Northern
        I like cupcakes & sh!tboxes
        • 5220
        shifter looks right, but it really doesn't look aligned in the hole. What engine mounts are you using?
        Originally posted by priapism
        Originally posted by shameson
        • e30de89
          • Sep 2006
          • 197
          It's a e36 carrier and condor tranny mounts.
          • Coupelx
            • Oct 2013
            • 169
            There was a thread about this recently. I believe you need to use the e30 carrier and selector rod.
            • e30de89
              • Sep 2006
              • 197
              That's what I was starting to think. I guess I'll have to source one out.
              Thanks guys
