M52 86' E30 Swap - How do I wire a check engine light
  • me30wW
    • Sep 2015
    • 6
    Have an m52 motor swapped 86 e30, its an early model which did not come w/ a check engine light. How would I wire in a check engine light? Its OBDI swapped. Thanks in advance!
  • DesertBMW
    • Aug 2011
    • 1036
    In Europe there was no "check engine" light on any of the BMW all the way until year 1999. You could wire in 12v LED, provide 12+ to it then negative trigger will come from the DME, that is your check engine.
    • me30wW
      • Sep 2015
      • 6
      One last question, which wire is the negative trigger?
      I thank you kindly friend!
      • 2mAn
        SeƱior Mod
        • 20814
        I think its pin8 on the X20. Gray wire IIRC
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
