Hi everyone i'm new to the forums and have a few questions about my m52 swap. I've looked around to see similar problems but no real solution's. if there is i'm sorry for re-posting and would appreciate a link!
So first things first
The car is a 85 318i, and have a m52 from a 98 323is. (stayed obd2)
ECU and harness
Got my ECU flashed my kassle performance and also got the custom plug and play harness from them so i didn't have to do any rewiring myself. (dont really trust myself doing all that haha)
The Problem
So when i go to start the car i hear my fuel pump prime and when i crank there is no start. I pulled the fuel-rail/injectors out of the manifold to see if they would spray but they just kinda spit out fuel. its not a strong mist at all.
I ran to a buddy's house to grab a fuel pressure tester and connected it to my shrader valve in the front of the rail and I'm not getting any fuel pressure.
also it will pop off using started fluid but dies out immediately.
My thoughts?
At first i thought it could be the fuel pump but I hear it prime up just fine.
then i was reading that i could be my Fuel pressure regulator? I know i have one under the driver side door but i don't have one in the engine bay.
I've seen the E39 fuel rail with the regulator connected to the fuel rail but if I bought that and installed it would i have to remove the one under the car? or can I get away with buying a certain one and installing it in my engine bay? I'm a little confused on all this.
I'd appreciate any help, thanks!
ECU and harness
The Problem
My thoughts?
