After S52 OBDII Swap Oxygen sensor not working
  • Jwilson4g63
    • Feb 2017
    • 163
    Ok so i have recently performed an s52 swap on my 91 318is. Everything went smooth until i let the car warm up. I'm tuning the car using open source so when i let my car warm up i was watching all the perimeters on my computer and realized once the o2 started to perform corrections bank one was pulling out 4-6% of fuel which i believe is fine since the injectors are slightly bigger then stock. Now bank 2 is pegging the computers limit adding 28% of fuel.
    Now onto diagnosing the issue: Start by attacking the easy thing first which was o2 sensors. So i swap the sensor(This is all in regards to pre cat) from bank 1 to bank 2 and the issue followed the sensor from bank 2 and now tells me bank 1 is pegging 28%. Pretty simple go buy a bosch o2 sensor replace bank 2 sensor and same thing is happening.
    Then i started to read up and saw that some bosch sensors don't work with the siemens ecu so i went and got a ntk sensor and the same thing is happening...
    Whats the possibility of getting 2 bad o2 sensors? do i have to drive the car to get the o2 to start reading properly? please any advise may help.
  • TobyB
    • 5297
    I would drive it.
    If you have something goofy like an open/leaking brake booster line,
    that'll affect trims/fueling a lot less under load.
    And then see what happens.
    Idle is only one of many driving conditions...
    Are you sure banks 1 and 2 aren't swapped?
    all I got.
    t
