Will S50 Crankshaft and NV rods in M50 block work?
  • mini612
    • 304
    I know for sure the beefier NV 135mm rods will not clear the block with M54b30 crank (Stroke - 89.6mm). So now, will the S50 crankshaft (Stroke - 85.8mm) clear the block with 135mm NV rods? Has anyone tried this? Thanks
  • digger
    • Nov 2005
    • 6196
    gets some S52 rods then
    • mini612
      • 304
      S52, M52B28, and m54b30 rods are the same and yes I know because I have them. I have seen and know people who used them in high power applications and many of them bend when hp reaches around 500. The only oem rods I’ve seen that that have been proven to with stand a lot of power are NV rods. Therefore, I’m planning to use NV rods or spend more cash and grab h-beams.
      • digger
        • Nov 2005
        • 6196
        a set of Molnar rods are quite economical and good quality. they have good clearance to so they even fit an m20 block with 89.6 stroke
        if the NV hit the bottom of bore with the shoulder of the rod then you can notch the bottom of bore
        • mini612
          • 304
          I was actually about to pull the trigger on some hbeam rods, then I saw someone selling a s50 crank (85.8) for crazy cheap, and the funny thing is, he lives a mile from where I live! Meant to be? So I grabbed it! I just test fit the nv rods and they pass. It is a “good to go”!
          Digger, thanks for your comments, I appreciate you taking the time. Thanks
          • The Dark Side of Will
            • Jun 2010
            • 2796
            If all it takes is notching the bores, I'd go for that 5% extra displacement. Now's the only time you'll be able to.
