S50 with G260 Swap Help
  • benloveless1
    • May 2017
    • 122
    I am about to embark on the S50 engine matted up to the G260 transmission. I am interested in knowing everyone's recommendations in regards to the clutch, pressure plate, flywheel, throw out bearing, pilot bearing, pivot pin etc. What did you use? What are the things I need to buy or tricks I need to know or do to make this process smooth?
    Thanks
    1988 BMW 325i Zinoberrot
    1984 BMW 533i Alpinweiss
    1986 BMW 528e Delphin Metallic
    1998 BMW 528i Touring
  • e30austin
    • 15382
    It's no different than your usual clutch job.
    I always use a late G260 behind a 24v engine and use all stock OE replacement clutch/flywheel/driveline/starter parts from a 325i. I run a stage two clutch masters kit in my red car and have been happy with it. If you want a firmer pedal, use a stock 325i clutch kit, and use the sport "618" Sachs pressure plate.
    • benloveless1
      • May 2017
      • 122
      Any reason why you didn't use the beefier S50 or M50 clutch kit?
      • e30austin
        • 15382
        Yes, a stock E30 325i clutch will hold the power just fine. If you are worried about it not holding the power (which is a non issue as I've done dozens of these conversions and used a stock clutch kit every time), buy the sport pressure plate.
        • benloveless1
          • May 2017
          • 122
          So M20 325i clutch kit, flywheel, pressure plate, pilot bearing, slave cylinder all for the getrag 260?
          • e30austin
            • 15382
            Correct. It all works well. Note that you'll need the 10 deg tilted trans brace and modified selector rod, as well.
            • benloveless1
              • May 2017
              • 122
              Yes sir I have ordered necessary parts to correct this. What about clutch pivot pin? Plastic? Brass? Stainless Steel?
              • e30austin
                • 15382
                Put back in what it already had, the stock plastic unit works just fine.
                • benloveless1
                  • May 2017
                  • 122
                  FX250 kit?
                  • e30austin
                    • 15382
                    FX250 kit?
                    That's what I installed, yes. Pedal feel is comparable to stock and engagement is right at the top of the pedal.
                    • benloveless1
                      • May 2017
                      • 122
                      aluminum or steel flywheel
                      • e30austin
                        • 15382
                        Stock 325i flywheel, back side shaved down to the ring gear for oil pan clearance
                        • benloveless1
                          • May 2017
                          • 122
                          Did you happen to purchase new flywheel and pressure plate bolts? If so what pressure plate bolts and which flywheel bolts?
                          • e30austin
                            • 15382
                            Yes, bought both for an '88 325is
                            make sure to use the flywheel shim that goes between the flywheel and the head of the flywheel bolts
                            • scabzzzz
                              Estado de mierda de encargo
                              • 6871
                              Evidently people like to use 323i euro throwout bearing, but otherwise all my stuff has been Sachs factory 325i stuff. Feels stock.
