Car Tilting to the right
  • Leonstt
    • Feb 2019
    • 81
    Hi guys, I just finished swapping my 1990 sedan from a 4 cyl M40B18 to M52B28 combined with E36 Getrag gearbox (off of a 323i I think). I noticed that the car tilts the the right a bit. When I measured it from a level ground to the top of the front arch, the difference is around 1 cm (right side being lower). Current suspension setup right now is Eibach spring (for 6 cyl E30) with Bilstein B4 shocks. Does anyone have the same problem as me? Thanks Sent from my SM-T875 using Tapatalk
  • TobyB
    • 5288
    This will be perfect if it's a LHD car- your weight will lower the left side 1cm, and it will be level.
    t
    • e30strokr
      • 211
      I seem to have the same problem... but to the drivers side, I found that my rear driver side subframe bushing has a lo of play when I put it up, may want to check that out
