S50 95 M3 Dme won’t ground O2 heater relay
  • Rxs7evin
    • May 2021
    • 2
    I’ve traced the entire circuit and everything works perfectly. The only issue is that the Dme will not ground the O2 heater relay. What are the conditions for the relay to be grounded? I’m leaning towards a bad Dme.
  • TobyB
    • 5298
    ummm- cold o2 sensor? As in, it should ground it until it gets a valid signal (not 0v) from it...
    t
    • Rxs7evin
      • May 2021
      • 2
      After testing it I found that the dme grounds the o2 heater relay when coolant temps get to 158f. After that the o2 sensor starts working fairly quick and the heater relay stayed grounded for the 30 min I watched it.
