Hello, I've recently got an s50 swapped e30 however the harness is cut and missing the maf sensor and iacv. I've got a new harness and adapter from an m50 and am looking for help on where all the sensors are located that need to be plugged in on the s50. If there is a good list or diagram of what needs to be plugged in and where it would be helpfully. The cut harness is still installed and labeled so it helps but some stuff is missing, just hooked up enough to start the engine.
Also I got the intake solution solved just unsure what hoses I need for the idle air control valve as the engine was missing it when I got it.
