No Head Lights after m50 swap.
  • xLegendOZWest
    • Jan 2009
    • 406
    so after i finished my swap i noticed i have no Headlights. i checked fuses, all good. audible clicking of both relays. i assume switch is good seeing as i have tail lights. any ideas?
    also i noticed my heater wont blow hot air. i think my hoses are laid out as follows
    line from front of engine is going to the upper line on the chassis.
    the line off the rear of the motor is going to the lower line on the chassis.
    backwards?
    idk. thanks for the help in advance.
    Live Fast. Drive Faster.
    "Nitrous is like a hot girl with an STD... :)
    You wanna hit it, but your afraid of the consequences :(
  • e30this
    • 3580
    You missed a wire that needs to be hooked up on the starter.
    I think its the black with green line...
    • hoveringuy
      • Dec 2005
      • 2733
      The unloader circuit is permanently unloaded.
      • etxxz
        • Feb 2006
        • 2085
        wire on the starter yep. you have no windows or sunroof either ey
        i did loose my headlights in the swap, but its not this and the high's work -.-
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
        • xLegendOZWest
          • Jan 2009
          • 406
          no i still got windows. and the starter wire (pin 15 i think) grn/blk is hooked up.
          how do i load said unloader?
          • hoveringuy
            • Dec 2005
            • 2733
            I don't have the specific wiring information with me, but theory of operation is that a number of high-load items are controlled by the "unloader relay" and are disconnected when you engage the starter. The relay is only supposed to get power when you engage the starter.
            I would start by DISCONNECTING that wire at the starter and seeing if those systems come back.
            • xLegendOZWest
              • Jan 2009
              • 406
              hmm. ill take a look. any ideas on the heater? its cold in Cleveland!
              • Rocla
                • 922
                I would start(and end succesfully) by GROUNDING that wire and seeing that those systems came back :)
                EDIT: after that unloader relay wouldn't unload ever again, but I see no trouble with that.
                EDIT2: grounding the black/yellow wire on starter causes a massive SC.
                Current:
                BMW 320i 2d 2.0 m20 -88
                BMW 325i Cabriolet 2.5 m50 -88
                BMW 316i touring 1.6 m40 -90
                BMW 320i 4d 2,2 m54 -01
                • xLegendOZWest
                  • Jan 2009
                  • 406
                  oh my. so ground the grn/blk ?
                  • Rocla
                    • 922
                    Yes.
                    Current:
                    • xLegendOZWest
                      • Jan 2009
                      • 406
                      does anyone know why the great minds at BMW did that? why not just ground through the chassis like everyone eles? its the only thing i found odd in bmw design so far.
                      • Rocla
                        • 922
                        The unloader relay is used to cut auxilary items suchs as mentioned while the starter is running.
                        Grounding the black/green wire makes the unloader relay stay closed whole time, so those items will work even is starter motor running.
                        So the wire is not for grounding, the starter grounds the unloader relay when the starter is not running.
                        I see no big trouble "bypassing" the unloader, the early e30's don't even have unloader relay.
                        You could also bypass the unloader relay (K5 in fuse box) by removing it and placing a suitable jumper wire between terminals 30 and 87.
                        Current:
                        • xLegendOZWest
                          • Jan 2009
                          • 406
                          Rocla is a very smart man. i finally understand it now.
                          • Rocla
                            • 922
                            Does your car work?
                            Current:
                            • xLegendOZWest
                              • Jan 2009
                              • 406
                              idk lol. ive been busy with clinicals. but ill let ya know when it does. i was just saying you were smart because your the first person to explain it to me and make sense.
