Hey guys,
I am new to the forum and I am having an issue with my car after wiring up the M52. I have exhausted all potential issues for the rough idle and I have settled on the Cam Sensor, not only because of the code but because of some items that I am about to describe. I first thought it was because I had a non-oem cam sensor so I changed it to two different OEM sensors and it still doesn’t work. I have tested the OHMs in the sensors of the Crankshaft sensor and the Camshaft sensor from the DME and I get 0.3 OHMs on both so I think that rules out any wire issues. Then I tested the volts on the Crankshaft sensor and the Camshaft sensor and I get 5v at the Crankshaft and 1.2 volts at the camshaft. From what I have researched it looks like I should probably get 2.5 volts at the camshaft sensor. This makes me think I have a bad DME. Any ideas or thoughts?
