M50 Compression Test Numbers!
  • Thicc
    • Apr 2022
    • 7
    So I bought a good compression tester gauge and I used it on my M50 non vanos (with m54b30 block internals)
    The gauge showed 240 on almost all cylinders, which is good that its consistent.
    But isnt the number way too high ? Or is it just me
    Sent from my SM-N950F using Tapatalk
  • TobyB
    • 5287
    Well, what's your calculated compression ratio?
    Given that a 2.5 can get close to 200, add a little gauge error and it doesn't seem all that high.
    How's the detonation?
    t
    • pazi88
      • Sep 2015
      • 584
      Only thing you really can tell from the compression test is that are the numbers consistent between cylinders. Sounds like it so all good.
