I was driving my car, and I didn't have any problems, until I was making a fast right turn. It sounded like something fell in my car, so when I pulled up to a stop light, I was looking around but could not find anything. When I accelerated, I was sitting at 40mph on the road, and the car started to act a bit strange. It was shaking the entire car. Between 40-50mph the car would shake violently whether it be in gear or out of gear. Under hard acceleration it seemed to even out and not shake as much, but as soon as I would let it get back down to 40-50mph it was horrible. The car at idle shook a bit more than normal also. Anybody have any ideas?
Violent Vibration Between 40-50mph
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinTags: None -
maybe you lost some bolts on your guibo84 318I Delphin RIP
87 325IS delphin 24v Sold
89 325 AlpineweissComment
I thought maybe it was the guibo or the csb. I replaced the csb and the guibo when I put the motor in. I'm hoping that it is that easy, but it seems like this car is just not that easy.
A good possibility. I need to finish up my girlfriends car and put my car up on the jackstands tomorrow evening.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
Don't drive it any more till you've figured it out, not worth the risk.Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
CSB for sure. Also your u-joints might have been damage because it sounds like your driveshaft is no longer balanced. Id throw it in the air, pull the driveshaft cover and have a look. If your Ujoints are fucked then find a driveshaft shop to crimp in new ones and have them proceed with balancing(works just fine, don't listen to anyone telling you otherwise.). Should cost no more then 200 for labor and i think 42.50 per Ujoint. Good luck.
Oh make sure they're using a machine that straps it down and calculates the balance. Eyeing it does not work with these cars!!!!Comment
a broken CSB will vib when you start from a stop too if it is all the way broken thoughbring it http://athomasmr23.mybrute.comComment
CSB won't cause idle harshness, but it could be your imagination. Did you lose any wheel weights from the rear wheels? Check trans and motor mounts, CSB bolts, guibo bolts, driveshaft to diff bolts.-P
Moosehead EngineeringComment
I definitely found out what at least 1 of the problems is. I finally got some time to look under the car during the day...
I'm missing a guibo bolt? o_O ?!
Gah this car is becoming a bit PITA!I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
Locktite!
Make sure nothing is damaged in the CSB area. I had a CSB break part of its strap once.-P
Holy shit! Never heard of just one bolt coming out.
Locknuts! Glad to hear you found a bit of the problem. Get another bolt on there with a locknut and check to see if the problem is gone with it on jackstands. If that checks out, then try a road test. Hope this is the fix! I'd personally recommend replacing the guibo and all the bolts.Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
That should be your only problem happend to me when I did my swap.
They need to be tight as fuck I threw a few. Then I added locktite and tightend the shit out of them and I haven had any problems. I bet you lost one and have a few that are not tight. Go threw and check all 6. you should be good to go after you fix the bolts84 318I Delphin RIP
Not yet. It should be fixed tomorrow. I bought the bolts today.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
