M50NV swap overheating
  • shiboujin
    • Feb 2006
    • 2791
    Background:
    M50B25NV boosted (shouldn't be the prob tho)
    M20 clutch and fan (no other fan)
    Regular M20 radiator
    I added coolant to my car and let it get to temp. The bottom radiator hose is cold and the top is hot. The car got to 209F before I shut it off. This is the second new thermostat I have installed. I made sure the bleed dot was at the top like the manual says.
    I can tell there is still some air in the system because I can squeeze the bottom hose and hear the bubbles slosh around. Maybe I should just tap a hole in the top of the thermostat housing and shove a bolt in it like the M20?
    I don't want to drain the coolant AGAIN! It'll be the 8th time (don't ask)
  • e30s52
    • Oct 2007
    • 5235
    Boosted cars have alot more heat to dissapate then non-fi cars. You need to get all the air out of system and get a better radiator.
    www.gutenparts.com
    • shiboujin
      • Feb 2006
      • 2791
      I know. I plan to upgrade the cooling system eventually but how do i get the air out without tapping the thermostat?
      • e30s52
        • Oct 2007
        • 5235
        You need a diffrent radiator but I guess if you dont want to get a new one just tap the the thermostat. I think its the easyest way.
        www.gutenparts.com
        • shiboujin
          • Feb 2006
          • 2791
          I don't get why it won't bleed with this radiator. It doesn't make much sense. What radiator should I get?
          • StereoInstaller1
            GAS
            • 22679
            The M42 cars have a radiator with an integrated coolant recovery tank.
            The bleeder is right by the cap, on the top of the radiator.
            That is why I have one sitting, waiting for the swappz.
            Closing SOON!
            Thanks for 10 years of fun!
            • e30s52
              • Oct 2007
              • 5235
              I would say an after market one from zionville or e36 m3 one.
              www.gutenparts.com
              • lifeiskaos
                • 1709
                come on yoshi get an electric fan with a low temp switch! should solve your problems... m20 radiator is certainly up for the task
                • 416stroker
                  • May 2008
                  • 2448
                  Your clutch good? How many turns does it make after you turn it off? Um it should bleed pretty easy.
                  84 318I Delphin RIP
                  87 325IS delphin 24v Sold
                  89 325 Alpineweiss
                  • shiboujin
                    • Feb 2006
                    • 2791
                    Clutch is new. How many turns? I dunno... a few?
                    I don't think the radiator is the problem here since the lower hose is stone cold and I can hear the air bubbles. Somehow, my system isn't getting bled when from all my reading, it should self bleed. I think the not being bled thing is keeping the T-stat from opening. Fuck it, I'm going to drill into my thermostat housing. Go M20 style
                    • hugh jass
                      • 2220
                      have you parked it nose up on an incline, taking the reservoir cap off, and revved up the motor for a couple of minutes? thats they way i've read most people bleeding their swap cars.
                      where did you read it should be self bleeding? that is definitely not the case.
                      ______________________
                      ex-Chief Operating Officer
                      Blunt Tech Industries
                      West Coast and Pacific Rim
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        Easy way?
                        Open the expansion tank. Squeeze upper radiator hose and hold it. Put your finger over the little hole in the expansion tank neck. Keep your finger over the hole and release the upper radiator hose. The coolant level in the tank should move down and you should have seen water/bubbles come out of the hole when you squeezed the radiator tank. Repeat this process until the coolant level no longer falls when you release the radiator hose.
                        That's the way that I have always done it.
                        My 2.9L Build!
                        • shiboujin
                          • Feb 2006
                          • 2791
                          Didn't rev it much but it was def nose up. I'll keep that in mind when doing it again.
                          Originally posted by PiercedE30
                          Easy way?
                          Dude that sounds great! I'll have to try that sometime today.
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            Yea, great thing about doing it that way, no need to have the motor running. Works like a charm. I've done it on anything from an E24 up through E46's.
                            My 2.9L Build!
                            • shiboujin
                              • Feb 2006
                              • 2791
                              It took a while but I think I got most of the air out. I'll try again tomorrow after running the car for a bit. Thanks man!
