M50NV swap overheating
  • hugh jass
    • 2220
    Originally posted by PiercedE30
    Easy way?
    Open the expansion tank. Squeeze upper radiator hose and hold it. Put your finger over the little hole in the expansion tank neck. Keep your finger over the hole and release the upper radiator hose. The coolant level in the tank should move down and you should have seen water/bubbles come out of the hole when you squeezed the radiator tank. Repeat this process until the coolant level no longer falls when you release the radiator hose.
    That's the way that I have always done it.
    I've never tried it this way. Do you keep your finger over the hole as you squeeze and release the radiator hose?
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • gregslow318i
      • Sep 2007
      • 1918
      on little trick that I learned is at the top of the term ware the little arrow is I like to drill a little hole like 1/4. makes bleeding the system about 10x faster and about 20x on a m20.
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • hugh jass
        • 2220
        'ware' is the 'term'?
        • shiboujin
          • Feb 2006
          • 2791
          could the heater hoses be backwards?
          • lifeiskaos
            • 1709
            wouldnt cause overheating, just no heat
            • shiboujin
              • Feb 2006
              • 2791
              hmm. I started the car up after that pierced said but I feel bubbles in the hoses again. *sigh*
              • evil_twin
                • Nov 2007
                • 2965
                is the front of the car jacked up Yoshi? give me a call.
                Paypal: vdang5@gmail.com
                Delta Auto Care
                2875-C Towerview Road
                Herndon, VA
                703.435.1375
                My Feedback Thread: Evil_Twin
                • shiboujin
                  • Feb 2006
                  • 2791
                  was the first time I tried to bleed it.
                  • FredK
                    • 14762
                    I used a 1/8" bit, and it made bleeding pretty easy. I just filled up the system really slowly, squeezed the hoses, and only had to top the coolant off a small amount.
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      You put your finger over the hole right before you release the hose, and put it on right after it has been released.
                      My 2.9L Build!
                      • evil_twin
                        • Nov 2007
                        • 2965
                        What temp thermostat are you running?
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • shiboujin
                          • Feb 2006
                          • 2791
                          I'm confused, then when do you take it off?
                          I squeezed the hose, put my finger over the hole, then released the hose. After it was done "unsqueezing" I released my finger and repeated.
                          That seemed to get most of the air out but then I started my car for a bit, turned it off and noticed more air bubbles in the hose (squeezed it and heard sloshing)
                          Stock temp... or lower. I don't remember. I've replaced it a few times.
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            That's exactly how I do it. (the way you did it)
                            You will be able to hear some water being sloshed around when you squeeze the hose. Honestly, since you have most, if not all, of the air bled, I would say to do some driving around and let the system finish bleeding itself off. Normally, with an E36, you do it the way that I said to and then bring the motor up to about 3000 and crack the expansion tank bleed screw open. The bleed screw is just a high point in the system, it would be the same if you took the expansion cap off and opened the throttle until nothing but coolant is coming out of the hole.
                            My 2.9L Build!
                            • shiboujin
                              • Feb 2006
                              • 2791
                              wish I could drive it around. I have a bunch more fab work to do. Thanks pierced.
