So now that I've gone wideband I'm curious about my AFRs. I'm running a TMS chip for Euro MAF and 24# injectors but I had 21.5# S52 injectors installed for awhile (NEVER trust ANYTHING you read on the internet.) Despite the undersized injectors everything seemed pretty ok (between 15.1 and 14.5 at idle and cruise and going up to the mid 12s under load) but last night I switched to Bosch Design IIIs (PROPERLY SIZED) and it's running rich (low 12s at idle, up to 10ish under load.) I know I have to give everything a chance to remap but is it bad to run an S50 on the rich side? Also, I figure unplugging the ECU for a bit could help everything reset, should I go ahead and do that or let everything work itself out normally?
Thanks!
Brendan
Thanks!
Brendan
