Ideal AFRs? Rich after injector change.
  • matt
    • 3731
    That's weird. There are adaptations that will take care of a lot of that though. And who's to say the TMS chip isn't programmed to be even richer than you were running?
      • 34835
      could it be a difference in injector characteristics? While they are usually pretty similar, injectors all have different response times and voltage correction curves. Maybe the opening time of the 21# injectors is shorter than the 24#s so it runs richer on the same PW.
      • e30polak
        • 6136
        Most guys on BFC, along with myself have experienced pig rich afrs with the 24# injectors+TMS tune.
        INSTAGRAM: @UNDR8D_EMPIRE
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          So am I hurting things by running rich? ADSS on sunday and HDPE on Thursday, I want to be in good shape for that...
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • matt
            • 3731
            Better rich than lean.
            • e30polak
              • 6136
              You will simply be making less peak power, then if you were to clean up the afrs.
              • Brew
                • 3060
                I'd think with afrs that low you would be maxing out the fuel trim adaptations (full negative) as the dme tries to compensate. Maybe your O2 sensor is sending the DME false signals?
                '91 318is
                • Fidhle007
                  • Oct 2005
                  • 7209
                  Hmm, well I have had no end of trouble with my 02 sensor (a problem that I could probably fix now that other people have run into the same issue) so my solution was to run the analog output of my LM-1 to my O2 signal and set it to mimic the stock 0-1v signal. So technically I have no O2 sensor anymore so what I'm seeing on the wideband should be what the DME sees too...
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    I'm now posting from the driver's seat of my car which is currently idling at stoich on the nose! It runs into the the 13s at high RPMs and may have a weird lean spot at 3500 but I think that goes away under load. It seems the secret to running a TMS 24# chip is to use S52 injectors...
                    • Brew
                      • 3060
                      Very interesting... I'm going to have to see where my AFRs stand once my car gets back from the body shop and I can get over to the dyno. I think I've actually got some S52 injectors lying around. Pink, right?
                      '91 318is
                      • Fidhle007
                        • Oct 2005
                        • 7209
                        Yep.
