Perma-cool fan
  • e30s52
    • Oct 2007
    • 5235
    Perma-cool fan
    So I am moving my car down to arizona and was wondering how well this fan keeps your cars cool. I know a few people on here have them just wondering how they like them and also where they got them from.
    So which one are you guys running? and where from?
    This is the only place I have found so far.
    Thanks,
    alex
    www.gutenparts.com
  • flyboyx
    • 8371
    any fan is better than none. a fan shroud will almost double its effectiveness. another option might be to get an e36 secondary(a/c) fan. that one is a quieter, more effecient blade design and comes with a better shroud design. if you do go with an electric fan between the engine and rad, make sure to get the thickness from the specs to be sure that it will clear. most people buy the fairly expensive spal. i assume you are asking about these products to save a bit of cash. remember, it doesn't have to be centered. you could probably offset the electric motor left or right to give you more clearance from the water pump pulley if you need it.
    Gigitty Gigitty!!!!
    • e30s52
      • Oct 2007
      • 5235
      No way a fan will fit in between the engine and rad. Right now I have a spal pusher fan that is doing a good job in washington but I am moving to arizona and wondering if I need somthing bigger because of the heat diffrence.
      www.gutenparts.com
      • dude8383
        • Jan 2005
        • 10387
        I bought myself the biggest spal that was available. Model # 30102047. Haven't installed it yet but I figure this thing should be powerful enough to keep temps in check during NYC heat/traffic.
        • e30s52
          • Oct 2007
          • 5235
          Right thats my current one right now. I am just wondering sence it gets up to 120 plus stop and go traffic would I need somthing bigger?
          www.gutenparts.com
          • MDryVur
            • 395
            im guessing your fan pulls right now... why dont you just get one more fan and place that in front of the rad. and have it as a push? i think that would do the trick especially in Arizona wheather. just my 2 cents
            • e30s52
              • Oct 2007
              • 5235
              I have a pusher fan right now. I just dont want to start driving it then have it over heat.
              www.gutenparts.com
              • yert315
                • 2734
                Get a curved blade fan if you don't have one already. They push more air and aren't as loud. Obviously the higher cfm, the better.
                I would say, see how your current fan performs in the heat before wasting money on another fan.
                o.t.
                What part of AZ are you moving to?
                • MDryVur
                  • 395
                  yeah that would be bitch... i think that's everyone's worry when having a e30s52 or any swapped motor
                  • e30s52
                    • Oct 2007
                    • 5235
                    Yeah basicly my biggest fear with this car. I cant fit a puller because the engine sits really close to the rad so I was thinking about getting a 16in. perma cool fan.
                    www.gutenparts.com
                    • hugh jass
                      • 2220
                      why not just run what you have now and see if it runs hot? it might be fine. don't throw money at a problem unless you know you have a problem.
                      ______________________
                      ex-Chief Operating Officer
                      Blunt Tech Industries
                      West Coast and Pacific Rim
                      • e30s52
                        • Oct 2007
                        • 5235
                        o.t.
                        Avondale, and my current fan is curved.
                        www.gutenparts.com
                        • yert315
                          • 2734
                          it's not running hot currently is it?
                          I used to live in AZ, just wondering what area you are heading to.
                          • e30s52
                            • Oct 2007
                            • 5235
                            Well I havent moved the car down here yet so I am trying to finnish everything while I have a garage before I leave.
                            www.gutenparts.com
                            • e30polak
                              • 6136
                              I used to have the 16" 2950 CFM fan. Works great, is easy to mount, and is one hell of a price. :D
                              A word of advice on this fan. It will hang down past the 1st valence opening, so any rocks/debris flying up will easily break a fan blade. That happened to my first one, after it happened a second time, I went with a Flew-all b/c of the fan shroud, and bc I got a sweet deal on it. :(
                              Your RD front looks to have even bigger openings, so you should block atleast the top one off somehow, to protect the fan.... ;)
                              INSTAGRAM: @UNDR8D_EMPIRE
