Perma-cool fan
  • e30s52
    • Oct 2007
    • 5235
    Yeah I was going to make a shrowd for it so nothing would get into it. The perma cool is almost the same price as my spal but double the cfm. Where did you get your fans from? I havent really found any good places yet.
    www.gutenparts.com
    • 318isbmw
      • Nov 2005
      • 2843
      I'm runnin one of the perma-cool's. 2950 cfm and its a 16" fan. I've got it on the e30 and then on my pickup, no issues in either. Wasn't a problem w/ the lowest temp m20 thermostat in the m50, no issues w/ the 100+degree spokane summer last year.
      • 325Projectz
        • Jan 2005
        • 1956
        what radiator are you running?
        btw, welcome to az.
        91 m3
        • e30polak
          • 6136
          http://store.summitracing.com/partde...5&autoview=sku
          Picked mine up from Summit as well.
          INSTAGRAM: @UNDR8D_EMPIRE
          • mazur
            • Jan 2006
            • 731
            I run a 16'' Lo Pro Spal (max 1300 CFM) in between my engine and radiator with no shroud. My needle will climb to the middle at most and sit there.
            I also use a little more water than coolant and a bottle of Water Wetter.
            Also, why move to Avondale? Unless you're going to UTI, I don't recommend it if you can help it. ;)
            • bostonbmw
              • Nov 2004
              • 429
              Is anyone running AC? I am wondering what fan I should get and how to mount while still keeping the AC?
              • e30s52
                • Oct 2007
                • 5235
                Trust me its not my choice. I do go to UTI (untrained idiots) but o well cant change it now. Right now I have an e36 m3 radiator. I guess I will just try and see what happens.
                www.gutenparts.com
                • xwill112x
                  • Jan 2009
                  • 4236
                  water wetter?
                  and if your tstat is good, should'nt that keep your temps in check?
                  • 318isbmw
                    • Nov 2005
                    • 2843
                    I'm running a e30 318i radiator and didn't have an issue in the hundred plus days in spokane last summer daily driving.
                    • e30s52
                      • Oct 2007
                      • 5235
                      Originally posted by xwill112x
                      water wetter?
                      Already using it plus I am running 75/25 water/coolent
                      Is that in the hundreds? I havent been in he spokane area in along time.
                      Originally posted by 325Projectz
                      btw, welcome to az.
                      Thanks, I hope to see people on here at the meets.
                      www.gutenparts.com
                      • 325Projectz
                        • Jan 2005
                        • 1956
                        you'll be more then fine if you have a fan and a temp switch.
                        i have a 318 radiator with my s52, it does fine driving around, but not so much in traffic... i'm going to change it back to my e36 m3 radiator as soon as i can get a custom overflow tank.
                        91 m3
