M52b28 with 318is gearbox question
  • Brinta
    • Jun 2024
    • 8
    Hello from the Netherlands 🙏
    Does anyone know wich clutch release bearing I need for this setup :
    M52b28 single vanos
    318is gearbox
    With m20 lightened flywheel
    M20 clutch
    Do I need the normal m20b25 clutch release bearing?
    I hear people buy the e30 323i bearing.. Cause it's taller?
    Or weld strips on the fork or something
    Other say just the m20b25 is just good enough
    Also what spigot bearing do I need?
    And m20 slave cylinder is good?
    Hahha so actually 3 questions 😅
    With kind regards
    Sander
  • TobyB
    • 5265
    Imma guess you need the single mass M20 G260 parts. Reason being the single mass stack- up's shorter
    than the dual mass, and the M42 (from whence your gearbox) is the same as the M20 for the trans mounting.
    Where I'm a little hesitant is that I don't know which gearbox you have-
    is it the overdrive G240/5 from an E30is?
    The E36 318is got the 1:1 5th, taller diff, and 'later' design box- the s5d250g.
    And as far as I've seen, that never came single mass- so it might be what the longer E21 323 throwout is used for.
    hth
    t
    • Brinta
      • Jun 2024
      • 8
      Thank you for the response
      Sorry.. I forgot to mention that the gearbox is from an e30 318is m42
      With the m20 flywheel being shaved off to 6.5kg
      So ok 323i for when u have the e36 gearbox.
      And in my case the 325i clutch release bearing is good
      Thank you so much
