In the middle of 1989 e30 to m50 obd1 swap that I took over.
Im all for diving into this wiring buy I cant find a pinout to save my life. The manual has the connector but Im looking for something that shows pin 1 is x and so on.
Somehow I have an always on issue with ignition even when switch is fully disonnected. Car will turnover but not getting fuel or spark.
I jumped fuel pump and git it going which means DME is not grounding things out.
I want to test ground continuity and supplied power to the DME as my next step... Im not sure where else to look otherwise.
If Im getting power and have continuity to ground it could be DME issue. Fuel relay doesnt click on when cranking.
Anyway... does ANYONE have a numbered pinout list?
