Can anyone help me know what harness pin is crank position?
  • Enriquez2000
    • Apr 2024
    • 152
    Getting frustrated. Cant find a pinout of the m50 vanos harness and I want to trace my crank sensor to make sure things werent plugged in backwards by previois owner.
    Ive tried the ETM but I cant find it... maybe im just frustrated and blinded by seeing red.
    Someone please help
  • ZinnoSuperEta
    • Feb 2024
    • 24
    On a M50 tu the crank signal wire is a yellow wire pin 16 on the DME. Crank position ground is a black wire pin 43 on the DME. On the sensor pin 1 is signal pin 2 is ground.
    • Enriquez2000
      • Apr 2024
      • 152
      Thank you!
      Dme pins counted right to left?
      • ZinnoSuperEta
        • Feb 2024
        • 24
        Here is a diagram for the pin numbers :)
        • Enriquez2000
          • Apr 2024
          • 152
          Click image for larger version  Name:	image.png Views:	0 Size:	37.3 KB ID:	10124233
          You the man!
          Hoping PO just plugged sensors backwards. Crank sensor ohm'd to 540 so it should be good
