Warm Start Issue
  • RenaissanceMan
    • Aug 2004
    • 237
    Warm Start Issue
    Motor is an S52 OBD2… When car is warm, car starts immediately and then dies. Requires gas application to ‘hold’ it at idle for a few seconds and then everything is fine. What component is most likely causing this?
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    I would start out by checking fuel pressure when it acts up. It could honestly be a lot of things, but I would use the OBD2 to your advantage. Are you getting any codes?
    • RenaissanceMan
      • Aug 2004
      • 237
      Nothing is throwing a check engine light but I haven't done a scan since this started to see if there were any pending.. Will take a look. Have checked fuel pressure already and all is normal but have not immediately checked again right after the symptom occurs. Will do that next. FWIW, virtually every single ignition/fuel/sensor component had been replaced, including the DME recently because I was chasing down a fuel adaptation issue for months that turned out to be a MAF problem. However, the MAF was replaced with another used MAF so I'm not sure how 100% it is operating. Could a suspect MAF act funny on warm starts?
      '90 325is/S52
      '76 2002
      '74 2002tii
      '06 325i sedan
      '05 X5 3.0i
      • jbontke
        • Mar 2019
        • 449
        Unplug the MAF and see if it idles when warm.
