Only 1 Coil no spark help please
  • Enriquez2000
    • Apr 2024
    • 152
    I have tested the wiring a few ways started with a coil and plug and changed out each set of coil wires and got spark arc when cranking on all but wires for cylinder 1.
    From there I tested the wires...
    power on I get 12v and ground with the multimieter and ground is good
    I checked the signal wire from harness to pin 50 and have continuity.
    what can I test next? I cant find anything that says what the signal wire should be tested at using multimeter.
    Also with wiring testing good is it possible the dme is bad and not sending a proper signal?
    Need to get this sorted so I can swap motors and nkt be chasing an already existing demon
  • Enriquez2000
    • Apr 2024
    • 152
    Well if anyone comes back was bad ecu
    • DesertBMW
      • Aug 2011
      • 1043
      you really can't catch a brake with this swap, it was a lemon from the start
