Alright... S52 OBD1 conversion question...
    • 37828
    Converting an S52 to OBD1. I have an S50 here, complete with all parts so no issue there.
    Here's my question...
    Can somebody give me the temp sensor wiring information? I'd rather do this myself than pay for a Turner adapter.
    Thanks guys.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • z31maniac
    • 17566
    The Turner Adapater doesn't work for E30s does it?
    www.gutenparts.com
    • e30s52
      • Oct 2007
      • 5235
      It doesnt. Dont buy it.
      www.gutenparts.com
      • lifeiskaos
        • 1709
        you cant use the s52 dual purpose coolant temp sensor. the resistance is different and will not work with the stock e30 temp gauge. there are a few options, but the easiest is to tap the head. use the coolant temp sensor for the ECU from the S50.
        • BeirBrennerE30
          • 2740
          to get the correct temp reading you need to use the e30 temp sensor so you need to
          a) tap the head and install like the obd1 motors
          b) buy the zionsville manifold and put it in your throttle body heater feed as close to the head as possible. (this is what I did!)
          c) install sensor n the place of the fitting for the feed for the throttle heater. I dont like this since no one can confirm that it doesnt screw up coolant flow in the head
          d) mount it into some other coolant hose. I think "the racers market" sells an adapter to put it in the upper rad hose.
          e30sport.net
          '06 M3 Competition - 6-speed
          '97 Range Rover Vitesse
          • Jean
            • 18228
            And they won't even return your calls...
            • e30s52
              • Oct 2007
              • 5235
              Yep or emails, calls, letters, etc... I wont buy from them ever again.
              www.gutenparts.com
              • hugh jass
                • 2220
                no shit. unless you are prepared to drop thousands of $$ with them they don't have time for you. i hope this shit economy teaches them some humility. fucking assholes.
                ______________________
                ex-Chief Operating Officer
                Blunt Tech Industries
                West Coast and Pacific Rim
                • hugh jass
                  • 2220
                  if you've got the engine out the cleanest and neatest way is to drill and tap the head.
                  • e30s52
                    • Oct 2007
                    • 5235
                    Yeah the one time they answer he says tough luck. Bunch of assholes.
                    O 3000 post.
                    www.gutenparts.com
                    • z31maniac
                      • 17566
                      I don't see how tapping the head is easier than using the Zionsville Manifold. Which is precisely what I plan on doing.
                      www.gutenparts.com
                      • FredK
                        • 14759
                        It's not easier, but it's cheaper and looks better to drill and tap.
                        I've never had to get any tech support from Turner, but they do put out some nice and affordable E30 chassis reinforcement products.
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          Just drill and tap the head.
                          Past Car : E30 S50 6 Speed 5 Lug 3.73
                          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                          ___________________________________________
                          BNB Designs
                          Engine Swaps, Fabrication, Innovation, General Repair
                          Richmond CA
                          Julian 848-248-8029
                          • BigD
                            • Jul 2006
                            • 1085
                            I filed down the sensor threads and re-threaded for the throttle body warming circuit nipple hole.
                            • Uber E30
                              • 1409
                              thats pretty slick
                              -Alex
