So my car is always quiet with normal, hard acceleration driving, but I've found after running several autocross events I get a pretty nasty valve tick. Starts with one or two then gets worse as its run around more. It will go away only after constant driving about 10 minutes.
I dont run an oil pressure or temp gauge, I've never got a low oil pressure light. I figure it has to be oil sloshing around in the pan and not getting to the pickup but I'd suspect a low oil pressure condition in those situations. Only other thing I gather is that the oil is getting hot and thining out, makes me almost think this as if it was a pressure issue it should go away after idling but it doesnt. I run 10 40 oil. Is there anything I can do with the oil pan as far as baffling the pan? I dont recall ever having this problem on my m50. I'm looking at getting gauges for the engine to see whats actually going on.
