DIY A/C Lines
  • dude8383
    • Jan 2005
    • 10387
    Originally posted by jahnaboi
    Yes. I had the lines since the beginning of my project. Luckily the motor I purchased came with them.
    Bmw a/c fittings? In comparison of the e36 fittings?
    Yeh I wanted to see what the E36 fittings look like.
    • ChuckNE
      • Oct 2007
      • 100
      Follow-up on my first post. This past weekend I replaced the dryer, expansion valve and all of the o rings in the system. I took the car into an A/C shop today to have the system vacuumed and filled with r134. No leaks and I have cold air. I think this will be one of my favorite mods beyond the S50.
      Also, I have read several posts about needing to run a signal wire to the DME to maintain idle with the A/C on...I didn't do this and have no issues with my idle (knock on wood). Good luck to everyone on adding A/C and I hope you find my DIY useful.
      • mrhinton
        • Nov 2008
        • 157
        this will be one of the first things i do to my 24v swap.
        • jahnaboi
          • Oct 2006
          • 1742
          Will be doing this on on Thursday before the Laker game to see how much I could get done. I'll snap a picture of all lines before and after.
          -Jasper
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • dude8383
            • Jan 2005
            • 10387
            -Jasper
            much appreciated man.
            did any of you guys just try reversing the a/c line? i think it fits...i'm going to try this weekend to confirm it. i gotta get a/c in before traffic kills me.
            • dude8383
              • Jan 2005
              • 10387
              Just wanted to bump this up as I will be tackling this once i get me some E36 A/C lines. Chuck, how long did it take these guys to get the parts to your door?
              • hugh jass
                • 2220
                not long, they arrive in a few days.
                in my experience, there wasn't enough room to put the splicer in the hose from the compressor to the condensor and still get it to bend enough. i ended up cutting the fitting off the e36 hose and welding it onto the e30 hose. the steel tubing is thin and it was tough to weld but my brother in law was able to do it.
                i haven't charged the system yet but all the hoses are hooked up. now onto the wiring....
                ______________________
                ex-Chief Operating Officer
                Blunt Tech Industries
                West Coast and Pacific Rim
                • e30s50dan
                  • Nov 2008
                  • 2076
                  thanks for the DIY,I am going to work on that right now,before the M50 swap
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • dude8383
                    • Jan 2005
                    • 10387
                    keep in mind that i have a 318is, my a/c lines don't go out as far as they would on the m20, so i think i will have enough room to get the splicer in there as i need to actually extend the a/c lines.
                    might be a stupid quesiton, but...what about the wiring?
                    it seems the o/p just hooked everything up and it worked.
                    • phreshkid
                      • 4655
                      man, you just saved me some serious miserability while driving.
                      the last two days it was 110, 106, and only god knows what he has in store for us today.
                      thank you, from the bottom of my heart and back.
                      • hugh jass
                        • 2220
                        getting the 413 ecu to idle the engine up when you hit the e30 a/c button so the engine doesn't bog and stall when coming to a stop. it isn't absolutely necessary but i like everything to work the way it was meant to.
                        • dude8383
                          • Jan 2005
                          • 10387
                          ohhh i forgot that the idle bumps up!! i haven't had a/c in sooo long man :(
                          o/p also mentions that he didn't have any issues with the idle, im willing to take a chance to see what happens and if it is an issue then i will have no other choice but to address it. for now though, i just want cold air to circulate.
                          • ChuckNE
                            • Oct 2007
                            • 100
                            I know there are several e36 lines that run from the compressor to the condensor at different angles. The original M3 fitting is angled in a way that it points straight down to the ground (Obviously this won't work). I found an e36 line at the pick-n-pull that had the correct angle to install the splicer in the hose. I know others have used the hose from a 91 318is and although a little long, can be made to work.
                            As far as idle issues. I do have a slight idle issue as the compressor cycles on and off, but no stalling and not really much of an issue. If I blip the throttle it holds steady.
                            • sharky
                              • Jan 2005
                              • 2672
                              just ordered mine, hope it works
                              • bmws50b30
                                • Aug 2005
                                • 1151
                                i need to bother you with this when you finish your a/c. we should have the same setup.
                                1991 330is
