Originally posted by jahnaboi
View Post
DIY A/C Lines
Originally posted by jahnaboi View PostAnd easier alternative if you wanted to get a lowside a/c to connect to your condensor, would be the a/c line from an e34 with a m50.
looks like i would still have to cut it and reposition it so that it could reach the condensor.Last edited by dude8383; 08-17-2009, 06:28 AM.IG: deniso_nsi Leave me feedback here
Originally posted by lifeiskaos View Post
Did anyone else try this method and face this problem as well?
Thanks
Wade
Originally posted by WADE30 View PostSo I got these adapters, and I was impressed until I found out the low line doesn't screw up to the compressor adapters. The E30 side is too large of diameter for it. The line from the condensor to the compressor is perfect but the other just isn't large enough.
Thanks
Wade
If I remember, I'll try to snap a pic of it over the weekend. I gotta get to a shop and have them run some dye through the system to figure where the hell the leak is.IG: deniso_nsi Leave me feedback here
Originally posted by dude8383 View PostYou know, I had the same issue...the dude simply started from the correct size clamp, then went down a size. Doesn't seem to be leaking but I know I have a leak somewhere else b/c the system lost its charge within a day...ultimate FAIL.
Cool! Let me know ASAP, I am in Phoenix and summer is approaching!!
Took some pics:
Last edited by dude8383; 02-07-2011, 08:43 AM.IG: deniso_nsi Leave me feedback here
Originally posted by sharky View Postjust bumping this because i am finally tackleing this and cant figure out which line to use from condensor to compressor. I have the compressor to bulkhead done but the other line has me guessing. Btw i am using the splices.
So I am about to install everything this weekend and I was wondering... Is it necessary to clean the lines out with some sort of solution? I ran some air with my compressor through them but I am sure that can only be so effective...
Oh and does anyone know the torque spec for the crank pulley bolts?
So who has gone the route that was mentioned on E30tech?
I'm tempted to do this because I finally got around to running the dye through the system and I honestly don't feel like having someone weld aluminum for me again. I feel like it will leak again :(
So I think I need this:
For this one what do you think I should get?
Last edited by dude8383; 02-07-2011, 08:48 AM.IG: deniso_nsi Leave me feedback here
