Anyone running RMS S/C kit?
    • 37832
    Yes, first pic is stage 2, second pic is stage 1.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • e30polak
      • 6136
      Stage 2 is the only way to go. That aftercooler is teh shizz nizz! :woowoo:
      INSTAGRAM: @UNDR8D_EMPIRE
      • rneedham1979
        • Jul 2008
        • 852
        As others have mentioned mine has the aftercooler. It is the same RMS kit though.
        Originally posted by M-technik-3
        Different as one has a aftercooler?
        Turbo E30
        Roadkill 80lb 93 octane OBDI tune
        BavSol Cylinder Head
        Stock S50 in. cam Schrick ex. cam
        Otis' tubular T4 manifold
        Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
        GT4094r w/Batmowheel Impeller
        614whp@17.5psi, 100 Oct
        690whp@21psi, 100 Oct
        801whp@27psi, 110 URT
        Old: 1/4 mile: 10.91@144.38 (636whp)
        New: ?
        http://www.youtube.com/watch?v=L_f7fUVqblI
        • flyboyx
          • 8371
          i have a couple of questions:
          does your car still have abs? i can't see the pump under the intake pluming.
          the wiring harness looks like the stock s52 harness. are you running obd2 with the super charger? wasn't obd2 tuning software about twice as much as for obd1? that has been my experience from the calls around that i have made.
          also, tell me about that custom aluminum tank on the driver side end of the radiator? most of the kits that i have looked at will conflict with the hose outlet on that side of the rad. i was wondering what was done there to get around that?
          also, what exactly is an after cooler? same as inter cooler? i have a facelift car and i want to know which inter cooler i can run without conflicting with the brake cooling duct.
          someone on one of these forums was selling a used sc kit that he was running on an s52ed e30. i was looking at it pretty closely, but the biggest problem is the software that comes with it would be a really big risk in my opinion. it may work perfectly, but the only way to check it would be to do a dyno run with an air/fuel readout. if it is off, you are looking at 800-1600 bucks to get proper software. it would be stupid to just run it without checking. for the amount he is asking, it would be so much safer to just buy the $3500 kit new and not risk blowing up your engine.
          Gigitty Gigitty!!!!
          • rneedham1979
            • Jul 2008
            • 852
            Yes it still has ABS, the engine is an S50 and it is OBD1. The tune I just purchased was 800 from Nick G. I am not sure what radiator is installed but I do not believe it is a custom unit.
            There should not be any upper radiator hose conflict since the kit is designed for this engine and the E36 radiators will fit in the E30.
            The aftercooler is between the charger and the throttle body, it uses coolant to cool the intake air before it enters the intake. There is a pump and a heat exchanger in the bumper which cools the water and pumps it to the aftercooler.
            As for you SW comments, I am not sure what you're talking about.
            Turbo E30
            New: ?
            • flyboyx
              • 8371
              yeah, now that i look closer at that engine, it is an s50. what are you using for an intake and where is it located?
              Gigitty Gigitty!!!!
              • rneedham1979
                • Jul 2008
                • 852
                the filter is on the drivers side behind the fog light.
                Turbo E30
                New: ?
                  • 37832
                  God damn it, I want one so bad!
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Spaz
                    Crazy Canuck
                    • 2276
                    Exactly the setup I want to run.
                    Cam .W '91 325is
                    Spaz's 1991 Alpine White???? S52 Build Thread...
                    • M-technik-3
                      • 18946
                      Just don't feel like spending another half a months pay on more car crud. Want one as well. M3 is going to shop when i get home off this trip and The 318Ti is theoretically sold.
                      I hopefully sold my alpine weiss 4 door so that will fund remainder of projects.
                      • rneedham1979
                        • Jul 2008
                        • 852
                        There are always used ones on BFC. I see them all the time....
                        Turbo E30
                        New: ?
                        • e30polak
                          • 6136
                          Not really, most people keep their RMS kits. The AA garbage is always for sale though. Rotrex blowers and AA tunes FTMFL. RMS Stage 2 or 3 + Nick-G tune FTMFW!!! :twisted:
                          • mattdk318i
                            • Jun 2006
                            • 3953
                            The sickness never ends. I was thinking of going SC but i know within a year or so ill be craving more boost.(minus changing pullys)
                            Im just going to say fuck it and go with da turboz.
                            • gobuffs
                              • Dec 2004
                              • 513
                              Osh is the man.
                              Haven't heard that in years....usually it is "Osh is a sonofabitch"
                              • evangreen
                                • Aug 2007
                                • 148
                                There are 2 for sale now on bimmerforums
