Cams interchange?
    • 37832
    Cams interchange?
    Can S52 cams swap directly in to an S50? And vice versa of course.
    Thanks,
    Matt
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • lifeiskaos
    • 1709
    no, you need s52 trays and lifters too
    • g22
      • 274
      Not to hijack... But do s50 cams drop into an m50?
      • dude8383
        • Jan 2005
        • 10387
        yes.
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          only vanos m50s though
          • e30polak
            • 6136
            Thanks,
            Matt
            Don't worry Matt, we'll figure it out. ;)
            INSTAGRAM: @UNDR8D_EMPIRE
            • lifeiskaos
              • 1709
              +1
              nonvanos are SOL when it comes to swapping cams
                • 37832
                God damn it!!
                Grover Beach, CA
                www.BimmerHeads.com
                • PiercedE30
                  • Apr 2005
                  • 4220
                  Originally posted by lifeiskaos
                  +1
                  Except for the exhaust side. Oh, and BMW did make GrouppeN cams for the NV.
                  My 2.9L Build!
                  • tonytony
                    Knee deep in poopie
                    • Jan 2004
                    • 3498
                    ^ which are hard to find, though i see some for sale on bf.c every now and then
                    • Uber E30
                      • 1409
                      realoem lists them as the same PN... is it wrong?
                      trays
                      lifters
                      -Alex
                      • ed94r
                        • Mar 2004
                        • 382
                        GrouppeN cams have the same specs as the M50 cams for lift and duration. The only benefit to Grouppe N cams is that they are blueprinted to be at the outer tolerance for the spec; ie the most lift and duration within spec tolerance.
                        The S50, M52, and S52 trays are all the same. The M50 trays are different. The NV M50 can be "hot cammmed" by moving the intaket cam to the exhaust side and purchasing a single intake side schrick cam. Don't know what specs to look for tho.
                        Ed
                        1988 E30/S50...now with S52; Track
                        1994 Miata R; ES Solo2
                        1998 Lexus LX470; Wife (Slee'd anyway)
                        2002 BMW 530i; A+ Commuter
                        2002 BMW 325iT; Sport/Premium 5-speed
                        2011 21' EconoTrailer
                          • 37832
                          ^ So this means my cams WILL swap in to the S52 and his came will go in to my S50?
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • Uber E30
                            • 1409
                            To the best of my knowledge, real OEM shows all the PN of the trays/lifters the same, and i had heard of s50 cams going in m52's with no change of lifters/trays. The ONLY difference in the s50 and s52 cams is one has a round core and one has a square core.
                            -Alex
                            • 1991 e30 bmw 318is
                              • 523
                              i was just reading up on bimmerforums today about cam swaps. probably going to get s50's for my m50. with a good tune its good for 20-30hp....not bad considering you can get them used for like 300shipped and direct bolt in.... then the chip will cost tho.
                              91 e30 318is M50 SOLD
                              http://www.r3vlimited.com/board/showthread.php?t=149570
                              92 325 vert project
                              http://www.r3vlimited.com/board/showthread.php?t=341370
