Hai guyz.
I am seriously thinking about swapping in a few more valves.
Lets be really clear about the goals of this swap though; this is NOT a race car.
Here is what I would like:
1. Better mileage
2. Quieter valvetrain/mechanicals
3. Cooler looks under hood
4. Less maintenance
5. Less RPM cruising on the freeway
6. about 10 to 20 more HP/TQ, and at lower RPM.
last but not least
7. Working A/C!
Currently, I have a nearly 300,000 mile M20, coming up on a timing belt shortly. Starting to leak LOTS of fluids, and has no working A/C.
My U-joints are getting crunchy, so the driveshaft will need to be rebuilt anyway, so that part of the equation is out.
Yes, I drive aggressively, but the car is a sport cruiser, does zillions of miles a year and is pretty beat. The 3.73 LSD is in OK shape, so I really don't want to change it.
Here is the big question: I want lower RPM on the freeway. I would like a bigger step between 4th and 5th, but in no way am I gonna spring for a 6 speed, or even swap the rear end gearing. The 3.73/G260 combo is 98% perfect, but just a few hundred RPM while cruising will make me happy.
The strength issue is moot as I will likely only put down 155ish RWHP with a bone stock M50NV, right?
I already own both of these transmissions, so cost of that part is NBD.
Fresh clutch is needed anyway, and flywheel is NOT gonna be lightened. Stop and go Seattle traffic, remember? No racecar bullshit at all, this is the DD for the foreseeable future.
What say you, R3V?
Luke
1. Better mileage
4. Less maintenance
last but not least
7. Working A/C!
What say you, R3V?
Luke
