I just got an e34 engine wiring harness for my 92' e36 engine,and cant figure out which connection goes to which sensor....does anyone know of a color code to sensor chart???
m50 engine wiring harness color code
Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
I was hoping to pull back the boots of the connectors,look at the color ,then match it with the sensor ...ie, crankshaft,camshaft,idle sensor,etc....anyone know the color code for a m50 wiring harness??NASA
BMWCCA member
PCA member 25yrs
1991 318IS slick top
1997 M3 sedan
2001 325CI DD
“whoever turns the wheel the least, wins"Comment
Like he said ^
Look in there for you car and engine, it'll list the wire colours for each sensor. Just have to do a bit of work.Comment
Most of the connectors can only go to one thing. Is it vanos or NV?Past Car : E30 S50 6 Speed 5 Lug 3.73
BNB Designs
Richmond CA
Julian 848-248-8029
it is a non-vanos 92' and harness is from a 92'e34..has more connections than my e36 does (my e36 harness is shot..looks like wires melted at the ECU side) the e34 harness has 4 3pins and 4 2pins for the area under intake..i looked at http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
and only shows the pin # of related sensor to ecuNASA
BMWCCA member
PCA member 25yrs
1997 M3 sedan
2001 325CI DD
There will be one more connection on the e34 harness - for the oil pan sensor. Possibly a traction control connector as well, as I believe more 5er's came with ASC+T then 3ers.Comment
bump. so i can save this and view it...Comment
