I'm trying to decide what to use for my S50 install. After rummaging around in my yard of junk cars, I came up with a 91 318is radiator, a 97 328is radiator, and an 84 524td radiator. The 524td radiator has a thicker core than the other two radiators.....basically, it has an extra row. I searched but was unable to find where anyone else has used one of these. I assume the mounts are the same as any e28, but not sure since I don't have any other e28s in my yard. Since I spend a good deal of time at my house in Vegas where next week is forecast for 112 degrees, I think the 524td radiator is probably the best choice. Any reason not to use it?
a different radiator option?
It appears that the 524td radiator is the same as used in the E32 V12 cars. Trial fitting just revealed that in order to use it I will have to fabricate custom mounts after removing the stock radiator mounts. The effort is not that difficult, but until I see that the e36 radiator is inadequate, I will probably not do it. I can always fit it in later.Richard
